Old 11-18-2014   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Turbo
For sale i have my Turbo and FP Race Manifold
-PTE 5031 400 obo about 10k miles on it give or take. Never been rebuilt works flawlessly. Just had Manifold surface decked and mounting threads serviced. Made 466whp at 28PSI stock 1G motor and a few bolt on's
-FP Race manifold 200 obo
-Engine/Head Combo Wiesco Eagle Rod Combo
-h11 heavy duty Studs
- MLS 5 Layer Headgasket
-BC280Camms
-ACL MAIN Crankshaft Bearings
-ACL Race Rod Bearings
-APR Rod and Main Studs&Bolts
-400 brake in miles on the clock
*Will have leak down test numbers and compression test numbers this weekend or so
-$1800obo Long Block assembly will not separate it would be a complete waste of a expensive head gasket
-5 Speed Transmission evo 3 internals double synchro 2nd gear
-$800
-6 .20over pistons new on good rods balanced and arp rod bolts make offer $150 for all 6
-ECM Link v3lite $450ob
-FIC 1450cc Injec $375
-Dual Walbro 255Fuel Pump Custom Backyard Hanger
-XTD Clutch stage 6puch $100
-Lc1 Wideband Gauge Needs sensor i believe comes with gauge $100
-Bullseye 50 trim needs rebuild $100
-GM maf $100 wrinkle black
-2G multi spoke wheels $300 black with tires
-2G TB Elbow $30
-Evo 8 Cat Back Exhaust 400
-Evo 8 Test Pipe 75
-235/40-45/r17 tires brand new make offer
PM for more detail or text 612 990 1570 Let's get this stuff sold! About 10k miles on my turbo give or take. 7-8kmiles or so on the transmission. 400 miles on the Long block. Turbo made Made 466whp at 28PSI on my stock 1G motor and a few bolt on's
