Old 12-03-2014   #1
DVS_DAN
DVS_DAN's Avatar
Drives: 2003 Mitsubishi Lancer Evolution 8 GSR
Help - Evo 8 Sunroof Motor
The motor mounting screws backed out completely and the motor eventually ripped from the wiring, as it must have sailed back and forth above my headliner. I cleaned up the wires and soldered them into the correct placement in the plug, I believe, but when I plug it in, nothing happens when I operate the sunroof button.
DOES ANYONE KNOW IF THERE IS A FUSE SOMEWHERE FOR THE DAMNED THING?
Here's the wiring as we figured it (6 & 7 are backwards though):
More circuit diagrams over here: http://www.evomn.net/forums/showthre...l=1#post134887
THANKS ALL!
DVS_DAN is offline   Reply With Quote
Old 12-11-2014   #2
DVS_DAN
DVS_DAN's Avatar
Re: Help - Evo 8 Sunroof Motor
Here is the fuse chart and a photo of the fuse block (ignore the yelow arrow). It doesn't make sense where the block of four fuses with the damn sunroof fuse (#21) is?!
Old 12-11-2014   #3
I think its this one just from looking at it, put a 10 amp fuse in there and see. Im no evo expert though.
Old 12-11-2014   #4
DVS_DAN
DVS_DAN's Avatar
Here is the engine fuse block for reference, no sunroof:
Old 12-11-2014   #5
DVS_DAN
DVS_DAN's Avatar
Not a bad idea to check the relays. i'll swap them around and test that out. i think I tried it a long time ago, but I'll do that first. I think they're a bitch to get out
Old 12-11-2014   #6
DVS_DAN
DVS_DAN's Avatar
Finally found something that looks promising: http://www.evolutionm.net/forums/evo...roof-fuse.html
"Fuse 21 is in an add on holder made of black plastic, lower left side of junction block, containing a 20 amp fuse."
Old 12-11-2014   #7
polishmafia
Smells like cat poop
polishmafia's Avatar
Just like I said in the SB. Follow the wires from the main fuse block, the square plug on the lower left, follow that to the add-on fuse block.
Old 12-11-2014   #8
DVS_DAN
DVS_DAN's Avatar
Shit, I think you might be right. I need to go look at my car. I wonder if it is hidden behind a bundle of wires.
*Ignore the arrows. Stolen from the internet
Old 12-11-2014   #9
polishmafia
Its right THERE. LOOK STRAIGHT UP FROM THE WORD FUSE. See that little yellow thing? Thats the black, add-on fuse block.
Its right there.
Old 12-11-2014   #10
Does it go to the right slot or the left slot?
I know you said right, but is it the left?
Old 12-11-2014   #11
DVS_DAN
DVS_DAN's Avatar
Its right there.
Werd. It was hidden and nobody called it out as behind the wires earlier
Old 12-11-2014   #12
polishmafia
Old 12-11-2014   #13
LMAO becuase you posted a shitty picture that had that entire fuse cluster covered. Pete you win this time! Shakes fist.
Old 12-11-2014   #14
polishmafia
I told you an hour ago, to follow the black wire coming from the square plug, from the bottom left of the main block. Follow the wire DOWN AND BEHIND to the black, add-on fuse block.
Old 12-11-2014   #15
DVS_DAN
DVS_DAN's Avatar
That plug isn't square
Old 12-11-2014   #16
I hope your sunroof still doesn't work when you put in a fuse.
Old 12-11-2014   #17
^^^Ahahahaha!
Old 12-11-2014   #18
DVS_DAN
DVS_DAN's Avatar
Damn kids. I wasn't able to check after lunch.
To be continued...
