Old 06-29-2015   #1
Fejery4491
Fejery4491's Avatar
Powdercoating thread
Anyone do any powdercoating? I just started and would love to talk technique with anyone with some experience
Did some sway bar brackets tonight in wrinkle black
Sorry for the supersized pictures, photobucket is being a pain and won't save my photos when I resize them
Old 06-29-2015   #2
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Powdercoating thread
Paging the CEO, the B-Man...
Old 06-30-2015   #3
Aka Jkodis
Old 06-30-2015   #4
And Powder Keg Coatings, they've done a lot of work for folks on here.
I have thought about doing this myself though since there's so many parts I want to do, it'd be cheaper to buy all the tools and materials myself.
Old 07-01-2015   #5
Fejery4491
Fejery4491's Avatar
Did a throttle body elbow in Mirror black today. Turned out pretty good, but I think I'll start to outgas any parts that are gonna be gloss black from here on out
Old 07-01-2015   #6
i used to do it out of my garage with an eastwood hobby gun. my only tips are the better the part is prepped the easier it adheres. Coating blasted parts was way easier. When coating thinga like valve covers, i always start by trying to coat the hard to reach nooks and crannys first, by the time those looked good a lot of the flat surfacea were already mostly coated. also it made a major mess in my garage, so after a couple years i just gave up.
pretty sure if you searched on here you wpuld find my powder coating thread from years back
Old 07-01-2015   #7
Fejery4491
Fejery4491's Avatar
Thanks for the pointers! I currently blast everything I coat. Did you ever use any sort of pretreatments? I've been seeing alot of guys using zinc phosphate. And it sure does make a mess, I'm working on a way to keep that to a minimum though.
Old 07-02-2015   #8
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Maybe putting up some 2 by 4 planks and make a small make shift booth just for spraying could help with the messy garage part? That can be quickly set up and broke down may help with the mess? Its what my carpenter buddy's suggest doing when we paint my car outside. Hmmm This is cool, you just heat it in a small oven or old stove?
Old 07-02-2015   #9
Fejery4491
Fejery4491's Avatar
Yeah i plan to make a small booth. I'm pretty concerned about losing any more floor space in my garage so that's the only concern. I'll either build it to be collapse or somehow make it to pull up to the ceiling when not in use.
Yep, im just using an old electric oven i got for free.
Old 07-02-2015   #10
Dark2g
Drives: 2gb gsx
You deffinetly should only use an electric
Oven from what I have read.
Old 07-04-2015   #11
Fejery4491
Fejery4491's Avatar
I've read this as well, but I'm pretty sure it only applies to small household ovens. I've seen plenty of very large gas ovens for large batch coaters. Like for instance the oven I use at a local manufacturing company for larger items is a gas oven. I think electric elements would take too long to get a 25'x15'x10' up to temp.
