Old 06-21-2004   #1
I just want to know what's ok to do.
I installed the fans on Sunday Morning, and after Enes showed me his fans he showed me that he used the stock Fan plugs. So I did the same. I cut the Plug and about 4" of wire.
The aftermarket fans came with 2 wires (1-blue, and 1-Black)
The Stock Plug has 4 wires (1-Blue, 1-Black,1-Yellow,1-Gree)
I have 2 fans: So I took all 3 Blue wires and soldered together, then took all 3 black wires and soldered them together.
Then I just plugged the "Fan" Plug into the passanger side Harness Fan Plug.
So did I wire them correctly or will I over run the system (meaning to many fans on one plug, etc?)
I was going to put on fan for 1 plug like stock but wanted them both to come on when the temps went up.
Anyways hope my rambling makes sense. I just don't want to fry my wireing harness or blow fuse's and then have to take everything apart once again.
Old 06-21-2004   #2
Enes
Enes's Avatar
I have the wiring all taped up but i will be pulling hte fans and moving them closer up a bit to the radiator, at that time i will give you the diagram.. and because the fans before were ran independently i would suggest doing it the same again. and also did you swap the blades from pull to push? make sur eyou put some lock tite on the nut otherwise it might come loose from the vibration..
Eric helped with my wiring, actually he ended up doing most of it. But we ended up using two wires for power for each fan and one ground.. reason is because before the fans used to be dual speed and when ecu kicks it into higher spead one of the wires will stop working.. and if we hooked it up to low then it wouldn't run.. if we hooked it up to high it would never turn on until the ecu tells it to go into higher speed..
-E
Old 06-21-2004   #3
Definetely post up the diagram when you get a chance. I was going to do it independently but I sold my other fan so I don't have an extra plug to use.
Actually come to think about it I think I have a spare fan in the attic.
Anyrate please post up. I don't want to wreck anything so close to the mayhem.
