Old 12-08-2015   #1
import_boi
Drives: ae86,2ga,
Fs: 95 gsx 6 bolt
Price: $5000 or best offer
Let me start off with what's wrong with it: the coolant temperature sensor clip broke off. That is all it needs to start up!
The goods: 90 percent of the parts are BRAND NEW!
Under 120k miles 6 bolt short block
Brand new head that has like 200 miles
L19 headstuds and cosmetic hg
Gates racing timing kit(water pump, tensioners and so on)
Balance shaft deleted
Full blown half size radiator with custom hoses (never over heated on the dyno or rush hour)
Fp race manifold ported n polished
Ported 16g with new waste gate preloaded @17 psi
Stainless j pipe
-10an oil return
Cx racing short Fmic
Gm iat and onmi 4 bar map
Ecm link sd wire harness
Ecm link v3 full
1g crushed bov
Walbro 255
-6an line from pump to fuel filter
Evo 560cc
-6an line to Fullblown fpr
Stock trans shifts like butter, no grinds
Act 2600 clutch kit with lighten flywheel
Reman axles (4)
Inner, outer tie rods, lower control arms,
Kyb agx
There's a bunch of stuff I'm forgetting.
Just ask and I'll try to answer to the best of my knowledge
import_boi is offline   Reply With Quote
Tags
best fs thread evar
