Old 05-13-2016   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Evo 8/9 Partout: FP, Tilton, Buschur, AMS, Volk, Cusco, SparkTech Etc
Evo 8/9 Multiple Evo Partout:
Ad is self explanatory, everything is in good-great shape unless stated otherwise. I'm located in Mankato MN. If its not listed I more than likely dont have it. If you can meet a day I'm at RS Motors or MAP or running other errands up there then I will absolutely meet you. If you need the parts ASAP come on down and get them!
Cell is 5072152103.
Thanks
Chris
Evo 8/9 Engine/Drivetrain/Turbos/Manifolds/Cams/Aftermarket
•Evo 8 Engine Longblock Oil Pan - Valve Cover (100xxx Miles) - $3300 shipped
•Evo ACD Tcase 60xxx miles - $1300 shipped
•Evo ACD Tcase 118xxx miles - $1200 shipped
•GT28 Complete Turbo Kit - PENDING
•DNP Coated Tubular Manifold (2k miles) - $700 shipped
•SSP Texas Evo Catch Can/Small Battery Tray Kit with Powder Coated Teal Valve Cover (8AN fittings/lines to CC) - PENDING
•ACT HDSS Extreme Pressure Plate/Streetlite Flywheel (Perfect shape! 200 miles on kit, bought new, swapped out for Exedy Twin) - $700 shipped
•ACT Lightweight Flywheel - $200 shipped
•Frontline Fab Rear Diff Cover BRAND NEW - $450 shipped
•3 Good Oliver Rods - $300 shipped
•Evo 9 Wrinkle White Valve Cover (two cracks but still seals fine) - PENDING
•AEM Methanol Kit - $350 shipped
•(3) Front Driver Axle - $140 shipped each
•(3) OEM Driveshaft in very nice shape - $100 each plus shipping
•Solid Front Motor Mount - $45 shipped
•MAF/K&N Filter - $60 shipped
Evo 8/9 OEM Parts/Sensors/Odds and Ends ETC.
•OEM Starter - $75 shipped
•(2) LIKE NEW OEM Evo 8 Water Pump (Idle time only) - $160 shipped or best offer
•(3) OEM Serpentine Belt Tensioner - $100 shipped
•(5) OEM Crank Pulley - $50 shipped
•(2 sets) OEM Balance Shafts - OFFER
•Evo 8/9 All 16 Rockers - $200 shipped
•Evo 9 OEM Intake Manifold/Throttle Body (No Sensors) $150 shipped
•OEM O2 Housing with O2 Sensor - $50 shipped
•(5) OEM Cam Gears - $25 shipped
•DSM BOV - $40 shipped
•(3 sets) OEM Evo 8/9 Ignition Coils - $50 shipped
•(4) OEM Fuel Rail - $30 shipped
•(2) Fuel Pressure Regulator/Line - $20 shipped
•Radiator Fan/Module - $120 shipped
•Radiator Fan - $80 shipped
•Radiator Fan Module - $40 shipped
•OEM Radiator Pipes – PM what ones you need
•(6) OEM Radiator Mounts – OFFER
•Evo 8 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
•Tons of AC Lines (Lmk what you need) - OFFER
•OEM Motor Mounts – PM with what you need
•(3) AC Compressor Bracket - $35 shipped
•(2)OEM Power Steering Bracket - $40 shipped
•Coolant Reservoir - $25 shipped
•(2) Power Steering Reservoir - $25 shipped
•(2) Front Windshield Wiper Motors - $30 shipped
•(2) ABS Module - OFFER
Evo 8/9 Suspension/Brakes/Wheels and Tires/Aftermarket
•LIKE NEW Volk RE30, 18x9 +35 with Toyo 265/35/18 (Wheels and Tires only have a few hundred miles) - $3400, wheels alone are $3600 new
•AMS Lightweight Cross Member - $220 shipped
•(2) Cusco Front Sway Bar - $150
•(2 sets) Drilled and Slotted Front and Rear Rotors- $100 picked up
Evo 8/9 OEM Suspension Parts
•(3) OEM Front Strut Bars – OFFER
•(3) Steering Columns with Ignition Switch/Key - $80 shipped each
•OEM Rear Control Arms – PM with what ones you need
•Front and Rear Wheel Knuckles/Hubs - PM what you need
•Evo 8/9 Front Subframe - $80 plus shipping
•OEM Mustache Bar - $100 shipped
Evo 8/9 Interior/Seats/Consoles/Trim ETC.
•Evo Recaros F&R Custom Seats with Carbon Fiber Style Inserts and Heated Front Seats. Comes with Custom Shift Console and Center Console and all wiring needed. $1000 picked up
•Evo 8 Blue Recaros Front and Rears - $600 picked up, $500 for just fronts
•Center Console - $50 shipped
•Shifter Console - $50 shipped
•Radio/Climate Control Bezel - $30 shipped
•(2) Lower Cubby for MR/RS Gauges - $30 shipped
•Glovebox - $40 shipped
•(3)Gauge Cluster Bezel - $25 shipped
•Evo 8/9 Interior Pieces (I have 3 cars worth or more) - PM what you need
Evo 8/9 Electronics/ECUs/Gauges/OEM Electonics
•Apexi AVC-R EBC - $350 shipped
•Evo 8 Gauge Cluster with Blue Bezel (93k Miles) - $140 shipped
•Greddy Boost Gauge - $120 shipped
Evo 8/9 Exterior
•Front and Rear Passenger Doors Tarmac Black -$250 each
•OEM Rear Bumper Tarmac Black - $300
•OEM Rear Bumper Weightless White - $300
•Evo 9 WW GSR Front Lip Great Condition - $150
•Passenger Side Mirror Tarmac Black - $40 shipped
•Evo 8 HID Ballast - $60 shipped
•Evo 8 RS Driver Headlight for spare parts, pm for info - $100
SOLD PARTS
•Evo 9 Cylinder Head – SOLD
•Evo 8 Transmission (118xxx miles) SOLD
•Evo ACD Pump – SOLD
•(2 set) Rear Axles - SOLD
•Passenger Front Axle - SOLD
•Driver Rear Axle - SOLD
•Driver Front Axle - SOLD
•AMS VSR Intake Manifold with Boomba 75mm TB/Sensors - SOLD
•Perrin Intake with MAF and Perrin Intake - SOLD
•AC Compressor - SOLD
•Water Pump Pulley - SOLD
•Evo 9 Exhaust Cam Sensor - SOLD
•Evo 9 Intake Cam Sensor - SOLD
•OEM Mivec Cam Gear - SOLD
•Ignition Coils - SOLD
•Set of OEM Motor Mounts - SOLD
•AC Compressor Bracket - SOLD
•Bilstein Front Struts and KYB rear Struts (No springs) - SOLD
•Evo 9 ECU - SOLD
•Braided Brake Lines All 4 - SOLD
•Kenwood Double DIN DDX318 - SOLD
•CF Wrapped Dash Pieces - SOLD
•Evo 8 NON HID Headlights (Very Nice Condition) - SOLD
•STM Oil Cooler with Lines Great Shape - SOLD
•Evo 9 5 Speed Transmission 93xxx miles - SOLD
•5 Speed Shifter Cables and Shifter Base - SOLD
•Evo 9 Shortblock (93xxx miles, dinged oil pan) - SOLD
•Evo 8 Rear Diff 103xxx miles - SOLD
•Evo 8 Rear Diff 118xxx miles - SOLD
•Mishomoto Radiator - SOLD
•GSC Race Balance Shaft - SOLD
•Evo 9 Bov - SOLD
•OEM Alternator - SOLD
•OEM Starter - SOLD
•MAF - SOLD
•OEM Valve Springs and Retainers - SOLD
•Fan Module - SOLD
•Brembo Calipers Front and Rear (Nice Condition)- SOLD
•Brembo Calipers Front and Rear (Faded) - SOLD
•Evo 8 Enkeis with Tires - SOLD
•Evo 9 Black MOMO Steering Wheel (Needs Airbag) - SOLD
•Vortex Generator Tarmac Black - SOLD
•Evo ACD Tcase 93xxx miles - SOLD
•Front Driver Axle - SOLD
•Evo 9 Turbo with lines/jpipe. Perfect Shape - SOLD
•Evo 9 Metal BOV- SOLD
•MAF - SOLD
•Ignition Coil Set - SOLD
•OEM Exhaust Manifold - SOLD
•OEM O2 Housing - SOLD
•Radiator Fan/Module - SOLD
•Evo 9 Coolant Hard Pipe and Thermostat/Sensors - SOLD
•AC Condenser Fan (small crack) - SOLD
•StopTech Slotted Rotors Front and Rear - SOLD
•Evo 8 Enkei Wheels and Like New Tires (PM for more info) - SOLD
•Cusco Rear Sway Bar - SOLD
•Evo 8/9 Rear Subframe - SOLD
•ACD Gauge Cluster 93xxx miles Carbon Fiber Overlay - SOLD
•Blitz Turbo Timer (Missing one button on display) - SOLD
•Buschur UICP with Tial BOV (wrinkle black pipe) - SOLD
•Exedy Twin Disc Needs Rebuild - SOLD
•ARP Extended Wheel Studs (10 new and 10 used in great shape) - SOLD
•OEM Power Steering Pump - SOLD
•OEM A/C Compressor - SOLD
•Sparktech CDI (2k miles) - SOLD
•Magnus Fuel Rail (8AN Feed and 6AN Return) - SOLD
•Tilton Hydraulic Twin Disc Clutch (0705-022 II-FO) - SOLD
•Aqua Mist Kit - SOLD
•Tial BOV "knock off" (Powdercoated Purple) - SOLD
•TPS Sensor - SOLD
•IAC Sensor - SOLD
•TPS Sensor - SOLD
•IAC Sensor - SOLD
•MAF and Injen Intake Adapter - SOLD
•OEM Fuel Rail - SOLD
•BRAND NEW Energy Suspension Rear Diff and Mustache Bar Kit - SOLD
•Lower Cubby for MR/RS Gauges - SOLD
•AEM EMS V2 - SOLD
•Blue Recaro's Front - SOLD
•Autometer Boost (45psi) - SOLD
•Autometer Air/Fuel (Missing Senor and some wiring - SOLD
•Evo 9 GSC S1 Cams - SOLD
•Evo 9 SE Rear Seats - SOLD
•Evo ACD Pump - SOLD
•FP Red Ball Bearing (2k miles w/Turbosmart Wastegate and Lines) - SOLD
•Fuel Lab FPR with Gauge - SOLD
•Injen UICP with Intake/MAF - SOLD
•EBAY FMIC (Dinged on bottom) - SOLD
•OEM Turbo Back Exhaust - SOLD
•Evo 8/9 Knock Sensors - SOLD
•Radiator Fan Module - SOLD
•Swift Springs SPEC R - SOLD
•2 Gauge Pod Steering Column - SOLD
•1 Gauge Pod Steering Column - SOLD
•Evo ACD Gauge Cluster (118k Miles ) - SOLD
•Alpine CD/Radio (CDA-9884) - SOLD
•Evo 6.5 RS TME Turbo (BRAND NEW) - SOLD
•Evo 8 Engine Longblock Oil Pan - Valve Cover (118xxx miles) - SOLD
•4" Intake/Tube (FP coupler to match 84mm Compressor Cover) - SOLD
•Buschur Turboback Exhaust VBAND (Great Condition) - SOLD
•TPS Sensor - SOLD
•IAC Sensor - SOLD
•Evo 8/9 All 16 Lifters - SOLD
•(2) OEM Throttle Body - SOLD
•Drilled and Slotted Rear Rotors - SOLD
•HVAC Control Unit (with revised cable from 2006) with Knobs - SOLD
•VIS Carbon Fiber Wingless Trunk painted WW - SOLD
2006 WW IX RS 396/404 - SOLD
