Old 12-10-2016   #1
97gsexx
97gsexx's Avatar
Drives: 97 talon
2002 gti 337
Selling my Volkswagen gti 337 if anyone is interested. 112k on body/100k on engine. NO RUST. Please buy it so I can buy mark's spyder haha.
Just had $6000 worth of maintenance and parts installed this spring:
(ALL BRAND NEW besides engine)
-stock ko3 turbo
-used 1.8t awp engine with 100k miles (bone stock)
-1.8t timing belt kit, water pump kit, and serpentine belt
-all new fluids for everything in engine bay
-1.8t oil feed line and return line and gaskets
-coolant pipe
-oil and coolant line installation kit
-valve cover set
-cam tensioner
-new exhaust gaskets
-brand new oem flywheel ($750)
-stock clutch
Have the reciepts for all the work done and parts installed.
Aftermarket parts:
-3" custom turbo back exhaust no cat (sounds amazing and spools loud)
-forge 007
-silicone hose kit
-oil catch can
-poly engine mounts
-fmic
-big turbo inlet pipe
-boost gauge and fuel pressure gauge, as well as wideband
-bilestein pss9 coil overs
-rear strut tower bar
-and more
NEEDs fixing:
-driver's door handle mechanism is broke so you have to open the door from the outside
-rear view mirror fell off
-small scratch above passenger rear wheel ( not very noticeable until really close )
- engine light on due to not running a rear o2 sensor
-cracked front lip (thanks mom)
That's it.
Asking $7500, please text me if interested 6126one66605. Thanks!
97 gsx (sold)
97 talon tsi awd 🐼
