Old 12-15-2016   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Evotuna's Biggest Partout Yet
Evo 8/9 Multiple Evo Partout:
-Ad is self-explanatory, EVERYTHING IS IN GOOD-GREAT WORKING CONDITION UNLESS STATED OTHERWISE. Texting is the best way to get ahold of me, email and pms will take me longer to get to. Shipping will be done over the weekends because I work a billion hours a week, unless it’s something I can ship out sooner, then I most certainly will. I have a couple hundred photos of the rest of parts so feel free to ask for more.
-I'm located in Mankato MN. If it’s not listed I more than likely don’t have it.
-Phone # 507-215-2103. Texting is preferred.
Thanks
Chris
ENGINE:
-Evo 8 Stock Shortblock (Seized up piston in one cylinder) - $1200 shipped
-Evo 8 Brian Crower 280/280 Cams - $330 shipped
-ARP L19 Headstuds - $130 shipped
-Evo 8 Valve Cover 8.5/10 shape - $220 shipped
-Evo 8 Valve Cover 7/10 shape - $180 shipped
-CF Spark Plug Cover Evo 8 - $70 shipped
TRANS/TCASE/DIFF/DIFF PARTS/AXLES/ACD PUMPS:
-Evo 8 Transmission 93k miles - $1300 shipped
-Evo ACD Tcase 100xxx miles - $1250 shipped
-Evo ACD Tcase 82xxx miles - $1250 shipped
-ACD PUMP GREAT SHAPE (70k miles. Missing solenoid and bracket is bent but pump works perfect when I used different solenoid) - $400 shipped
-Frontline Fab Rear Diff Cover BRAND NEW - $440 shipped
-OEM Front Axles - $250 shipped for a set or $125 each
-OEM Rear Axles - $250 shipped for a set or $125 each
TURBOS/WASTEGATES/FMIC/PIPING/MINI BATTERY/RADIATOR/COOLING:
-FP Zero Ball Bearing with Install Kit and MAP Downpipe (EVERYTHING IS BRAND NEW) - $3100 shipped
-FP Black Ball Bearing with Install Kit and STM Downpipe (EVERYTHING IS BRAND NEW) - $3100 shipped
-Garrett GT3582R ATP-VEVO-006 Full Kit - $2200 shipped
-Evo 8 9.8 Turbo Comes with Wastegate/Lines/OEM Exhaust Manifold/Megan O2 Housing - $350 shipped
-AMS 3.5” FMIC Great Shape - $525 shipped
-AMS UICP Great shape - $260 shipped
-Unknown Mini Battery Tray - $70 shipped
-Koyo Radiator BRAND NEW - $325 shipped
-Mishimoto Aluminum Slim Fan Shroud Kit with Fan BRAND NEW - $220 shipped
-OEM Radiator with Slim Fan and Shroud - $160 shipped
-Samco Radiator Hoses Blue (4/5/6) BRAND NEW - $100 shipped
EXHAUST/INTAKE MANIFOLDS/INATKES/BOVS/MAFs:
-DNP Coated Tubular Manifold (2k miles) - $600 shipped
-(2) Invidia O2 housing - $150 shipped
-STM Lightweight Ultra Quiet Resonator BRAND NEW - $240 shipped
-OEM Turboback Exhaust - $200 picked up
-Aftermarket Straight Pipe Exhaust (test pipe back, no downpipe) with Perrin test pipe welded to it - $100 picked up
-Speed Density Intake (Brand New) - $160 shipped
-Perrin Recirculating BOV- $180 shipped
-(2) Stock Turbo Intakes - PM for pricing
IGNITON/FUEL PUMPS/INJECTORS/RAILS:
-Magnecor Ignition Cables - $75 shipped
-(2) Walbro 255 - $40 shipped
-OEM Hanger Modified with a 6AN feed (Missing fuel level) - $50 shipped
CLUTCH/FLYWHEELS:
-ACT HDSS Clutch Kit with ACT Flywheel - $400
-ACT HDSS Clutch Kit with ACT Flywheel - $350
-ACT Lightweight Flywheel - $140 shipped
-Fidanza Flywheel - $60 shipped
RANDOM AFTERMARKET PARTS:
-Braided Clutch Line - $40 shipped
-PlastiDip Kit for 4 Wheels (One extra can of black as well) ALL BRAND NEW - $40 picked up
GAUGES/ECUS/RADIOS/ELECTRONICS/OEM ELECTRONICS:
-AEM Digital Tru-Boost BRAND NEW - $290 shipped
-AEM Spec Ops Serial Cable BRAND NEW - $25 shipped
-E85 Flex Fuel Sensor - $80 shipped
-Alpine Radio (CDE 110) - $40 shipped
SUSPENSION/BRAKES/WHEELS AND TIRES/AFTERMARKET AND OEM:
-LIKE NEW Volk RE30, 18x9 +35 with Toyo 265/35/18 (Wheels and Tires only have a few hundred miles) - $2500
-Swift Lowering Springs Spec R (Bilsteins) BRAND NEW - $300 shipped
-Ichiba 10MM Wheel Spacers (All 4, BRAND NEW) - $160 shipped
-Whiteline Rear Sway Bar BRAND NEW - $180 picked up
-Whiteline Roll Center Kit with Tie Rod Ends in Lower Control Arms - $380 shipped
-OEM Aluminum Front Strut Bar (RED) BRAND NEW - $350 picked up
-OEM Front Control Arms – $120 shipped each
-OEM Rear Control Arms – PM with what ones you need
-(3 sets) OEM Chassis Braces - OFFER
-(2) OEM Front Strut Bars – OFFER
-(3) Steering Columns with Ignition Switch/Key - $80 shipped each
-(2) Rotor Shields - $30 shipped
OEM INTERIOR/SEATS/CONSOLES/TRIM:
-Evo 8 Blue Recaros Fronts and Rears - $600 picked up
-Evo 8 Blue Recaro Pass Front Seat - $150 picked up
-OEM Blue Weighted Shift Knob BRAND NEW - $80 shipped
-(2) Steering Wheel Single Gauge Pod Holder - $30 shipped
-(3) Steering Wheel Cover $15 shipped
-Lower Cubby for MR/RS Gauges - $30 shipped
-(2) Glovebox - $40 shipped
-(3) Gauge Cluster Bezel - $25 shipped
-Evo 8/9 Interior Pieces (I have 3 cars worth or more) - PM what you need
-Dimmer Switch - $15 shipped
OEM/AFTERMARKET EXTERIOR PARTS:
-Evo 9 Front Bumper White GREAT SHAPE (Brackets and mesh pieces are included but no installed on bumper) - $800 picked up
-Evo 9 Front Bumper Lip BRAND NEW (ebay poly) $50 picked up
-Rear Bumper Tarmac Black OEM - $200
-Rear Bumper Weightless White OEM - $200
-Evo 9 WW GSR Front Lip Great Condition - $100
-Evo 8 Tail Lights (No bulbs or wiring) - $80 shipped
-Tarmac Black Gas Door - $40 shipped
-Hood Latch - $35 shipped
-(2) OEM Gas Cap - $15 shipped
-Evo 8 Bumper Mesh/Vents – PM what you need
Evo 8/9 OEM PARTS
SENSORS:
-Crank Sensor - $60 shipped
-Brand New Exhaust Cam Sensor - $65 shipped
-(3) Knock Sensor - $50 shipped
-(2) Evo 8 MAP Sensors - $40 shipped
-(2) Evo 9 MAP Sensors - $40 shipped
-(3) Oil Pressure Switches - $15 shipped
TIMING:
-Box of Like New Timing Components – PM Me
-Evo 8 Timing Belt (Like New) - $50 shipped
-Evo 9 Gates Timing Belt - $70 shipped
-(4) AC Delete Serpentine Belts - $20 shipped
-(2) LIKE NEW OEM Evo 8 Water Pump (Idle time only) - $80 shipped or best offer
-(3) OEM Serpentine Belt Tensioner - $75 shipped
-(6) OEM Crank Pulley - $40 shipped
-(3) OEM Serp Belt Idler - $30 shipped
OEM EXAUST MANIFOLDS/O2 HOUSINGS/INTAKE MANIFOLDS/THROTTLE BODY:
-(4) OEM Driveshaft in very nice shape - $100 each plus shipping
-(3) OEM Exhaust Manifold - $50 shipped
-OEM O2 Housing with O2 Sensor - $50 shipped
-(4) OEM Intake Manifold - $75 shipped (Three have EGR still and MAP Sensor)
-DSM BOV - $30 shipped
STARTER/ALTERNATOR/WIREHARNESSES/POWER STEERING PUMPS/AC COMPRESSORS:
-OEM Alternator - $90 shipped
-(4) OEM Starter - $90 shipped
-Evo 9 Engine Wire Harness - $350 shipped
-(2) Evo 8 Engine Wire Harness - $280 shipped
-(4) AC Compressors: $130 shipped
OEM ENGINE PARTS/BRACKETS/ENGINE BAY PARTS:
-Evo 8/9 Rockers – $200 shipped per set
-(6) OEM Cam Gears - OFFER
-(2 sets) OEM Evo 8 Cams – OFFER
-OEM Valve Springs - $40 shipped
-(3) MIVEC Oil Line - OFFER
-(4) Oil Dipstick with Tube - $30 shipped
-OEM Motor Mounts – PM with what you need
-(5) Motor Mount Bracket to Block - $80 shipped
-Master Cylinder - $50 shipped
-Clutch Master Cylinder- $60 shipped
-OEM Clutch Slave - $50 shipped
-Evo 8 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
-(3) Evo 8 Coolant Hard Pipe - $40 shipped
-(2) Evo 9 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
-Evo 9 Coolant Hard Pipe - $40 shipped
-Evo 8/9 Thermostat Housings with Sensors - $60 shipped
-(6) Block to Trans Shield with Starter Hole – $30 shipped
-(2) Flywheel Shields (Under block, bolts into trans) - $25 shipped
-(7) AC Compressor Bracket - $25 shipped
-Power Steering Pump Bracket - $35 shipped
-(3) Coolant Reservoir - $25 shipped
-Power Steering Reservoir - $25 shipped
-(2) OEM Battery Tray (One is missing top bracket) - $30 shipped
-(2) Hood Prop - $20 shipped
-(2) Front Windshield Wiper Motors - $30 shipped
-(2) ABS Module – OFFER
-Evo 8/9 Injector Resistor Pack/Bracket - $40 shipped
-Evo 8 Lower Timing Cover - $45 shipped
-Evo 8 Spark Plug Cover - $20 shipped
-(2) Evo 8/9 Horns - $10 shipped
OEM IGNITION/FUEL/RADIATORS/FANS/PIPING/MODULES/AC LINES:
-OEM Evo 8/9 Ignition Coils - $70 shipped
-(2) OEM Evo 560cc Injectors - $100 shipped
-OEM Fuel Rail/FPR - $40 shipped
-(2) OEM Fuel Rail - $30 shipped
-OEM Radiator - $120 shipped
-(2)Radiator Fan/Shroud/Module - $80 shipped
-(3) Radiator Fan/Shroud no Module - $50 shipped
-(2) AC Condenser Fans - $75 shipped
-(6) OEM Upper Radiator Pipes - $20 shipped
-(9) OEM Lower Radiator Pipes - $20 shipped
-(6 sets) OEM Radiator Mounts – OFFER
-Tons of AC Lines (Lmk what you need) - OFFER
SOLD:
-Evo 8 Built Cylinder Head Ported, Ferrea Valve Springs and Retainers
-Kelford 272s
-ACD Pump GREAT SHAPE (60k miles)
-Weir Maxgrip 12 Plate Rear Diff Kit BRAND NEW
-Evo 9 Turbo Comes with Wastegate/Lines/Jpipe (Good condition light shaft play, stock boost its whole life)
-Buschur Double Pumper (3K miles and great shape everything needed for install)
-Nitrous Kit
-JDM Rear with Tow Hook Cover ALL BRAND NEW
-(2) OEM TB
-STM Oil Catch Can with Purple Russell Fittings ALL BRAND NEW
-STM Front Crash Beam BRAND NEW
-Solid Front Motor Mount
-Avid 5speed Trans Mount
-Avid Passenger Side Engine Mount
-MAF
-SpoolinUp COP NON CDI (Brand New, will include Spoolinup Easy Injector Connectors)
-Evo 8 Cylinder Head with Kiggly Valve Springs and Retainers
-Evo 8 Brand New Cometic Headgasket (C4157-051)
-Cusco Catch Can
-Avid Rear Engine Mount BRAND NEW
-Evo ACD Tcase 60xxx miles
-Mishimoto Half Sized Radiator with Fan
-Magnus Fuel Rail with line
-Walbro 450 BRAND NEW
-AEM Digital Fuel/Oil Pressure BRAND NEW
-Greddy Boost Gauge
-Autometer Gauges (Boost/Oil Pressure/Volts with A-Pillar 3 Gauge Pod
-Prosport Voltage Gauge
-Center Console
-Evo 9 Climate Control Box
-Fuel Pressure Regulator/Line
-Evo 8 5speed Trans 82xxx miles
-Evo 9 Turbo Comes with Wastegate/Lines/Jpipe (Great shape no shaft play)
-AMS Mini Battery Tray
-Odyssey PC680 Mini Battery with Odyssey Battery Charger ALL BRAND NEW
-Evodynamics Ported Stock Exhaust Manifold
-Buschur Ported Stock Exhaust Manifold
-Weldon Surge Tank Kit
-Torque Solutions Driveshaft Carrier Bushings BRAND NEW
-AEM Digital Tru-Boost (LIKE NEW)
-Brembo Rear Set
-OEM Blue Pedals BRAND NEW
-OEM Alternator
-3 Good Manley Turbo Tuff Rods/Manley Pistons
-3 Good Oliver Rods
-Buschur Mustache Bar GREAT SHAPE
-Buschur Rear Diff Side Mount Kit BRAND NEW
-BBK Full Ball Bearing Turbo (5k miles, great shape)
-Evo 9 OEM Wastegate
-AMS LICP Great shape
-Used Samco Radiator Hoses Blue
-Mishimoto Aluminum Coolant Reservoir BRAND NEW
-Buschur Ported Intake Manifold
-Full Race Tubular Manifold
-Perrin Downpipe
-3” Vband Test Pipe (Both ends)
-STM Intake/K&N Filter with MAF
-(2) Torque Solutions Exhaust Mounts
-AEM Digital Fuel Pressure Gauge
-AEM 5 Bar Map Sensor
-Zeitronix Flex Fuel Gauge ECA-2 BRAND NEW
-Greddy Turbo Timer with harness
-Evo 8 Enkeis with Brand New Eagle Eagle GT Tires 235/45/17
-Rexspeed JDM Carbon Fiber Exhaust Cover
-Seibon CF Hood (Faded but in good condition)
-Evo 8 RS Driver Headlight for spare parts, pm for info
-Evo 8 HID Ballast
-Cam Sensor Housing (Exhaust) Evo 8
2006 WW IX RS 396/404 - SOLD
