Old 02-10-2017   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
EvoTuna's Tax Season Partout!
Evo 8/9 Multiple Evo Partout:
-Its TAX SEASON B*tches!! Build your Evo or fix your broken sh*t, I’ve got enough here to do it all.
-Ad is self-explanatory and its sorted by category. Do yourself and me a favor by reading through the ad.
EVERYTHING IS IN GOOD-GREAT WORKING CONDITION UNLESS STATED OTHERWISE. Texting is the best way to get ahold of me, email and pms will take me longer to get to.
-I'm located in Mankato MN. If it’s not listed I more than likely don’t have it.
-Phone # 507-215-2103. Texting is preferred.
Thanks
Chris
ENGINE:
-Evo 9 Built 2.0 TSCOMP Built, Manley Turbo Tuff Rods, Wiseco Pistons, Curt Brown Ported Head, GSC S3s and Valve Springs, Ferrea Valves (2k miles) - $6500 shipped
-Evo 8 Stock Shortblock with Crank (Freshly Machined to .020 over PM for more details) - $1200 shipped
-STM Sealed Oil Catch Can Brushed Aluminum and STM 3.5" Vented Intake Pipe Polished for STM Sealed Catch Can (http://www.streettunedmotorsports.co...ch_can_new.htm and http://www.streettunedmotorsports.co..._catchcan.htm- $660 shipped
-Torque Solutions Motor Mounts (Side mounts and rear mount) - $250 shipped
-Avid Rear Engine Mount BRAND NEW - $75 shipped
-OMNI 7Bar MAP Sensor - $80 shipped
-Hallman Pro MBC (Black) - $70 shipped
-Grimmspeed MBC (Blue) - $70 shipped
-ARP Standard Headstuds - $60 shipped
-Evo 8 Valve Cover 9/10 shape - $200 shipped
-Evo 8 Valve Cover 7/10 shape - $150 shipped
-Aluminum “Evolution” Spark Plug Cover with Hardware - $110 shipped
-CF Spark Plug Cover Evo 8 - $70 shipped
TRANS/CLUTCHES/TCASE/DIFF/DIFF PARTS/AXLES/ACD PUMPS:
-Evo ACD Tcase 100xxx miles - $1150 shipped
-Evo ACD Tcase 82xxx miles - $1150 shipped
-Evo ACD Tcase 87xxx miles - $1150 shipped
-Evo ACD Tcase 79xxx miles - $1150 shipped
-Evo 8/9 Rear Diff (82k miles, No Ears on it) - $650 shipped
-Driveshaft Shop Carbon Fiber Driveshaft (1k miles) - $1250 shipped
-Frontline Fab Rear Diff Cover BRAND NEW - $400 shipped
-OEM Front Axles - $250 shipped for a set or $125 each
-OEM Rear Axles - $250 shipped for a set or $125 each
-Competition Clutch 6 Puck Disc and Pressure Plate - $140 shipped
-ACT Lightweight Flywheel - $140 shipped
-(2) OEM Flywheels - $75 shipped
-Fidanza Flywheel - $50 shipped
-5speed Shifter Cables and Shifter Base with Aftermarket Bushings - $150 shipped
-Buschur Racing Shifter Base Bushings - $20 shipped
-Braided Clutch Line Full Line - $40 shipped
-(2) Braided Clutch Line (Half Line) - $20 shipped
TURBOS/WASTEGATES/FMIC/PIPING/MINI BATTERY/RADIATOR/COOLING:
-FP Zero Ball Bearing with Silver Tial Wastegate/Oil Line (EVERYTHING IS BRAND NEW) - $2200 shipped
-FP Black Ball Bearing with Red Tial Wastegate and Oil Line (EVERYTHING IS BRAND NEW) - $2400 shipped
-FP Zero Ball Bearing with Install Kit with Vband O2 Housing/Downpipe (2k miles) - $2200 shipped
-Evo 8 9.8 Turbo Comes with Wastegate/Lines/OEM Exhaust Manifold/Megan O2 Housing - $350 shipped
-AMS 3.5” FMIC Great Shape - $525 shipped
-AMS UICP (Stock BOV) Great shape - $240 shipped
-ETS Mini Battery Tray (Missing Tie Down) - $80 shipped
-Unknown Mini Battery Tray - $70 shipped
-ETS Mini Battery - $80 shipped
-Odyssey PC680 - $80 shipped
-Megan Racing Radiator with Slim Fan - $160 shipped
-OEM Radiator with Slim Fan and Shroud - $160 shipped
-Samco Radiator Hoses Blue (4/5/6) BRAND NEW - $100 shipped
-Samco Radiator Upper/Lower Hoses Black (USED) - $60 shipped
EXHAUST/INTAKE MANIFOLDS/INATKES/BOVS/MAFs:
-Curt Brown Ported Intake Manifold and Ported Throttle Body (No Sensors) - $520 shipped
-(2) Invidia O2 housing - $140 shipped
-Buschur Racing Cat Back Exhaust (Straight pipe to muffler) - $300 picked up
-OEM Turboback Exhaust - $150 picked up
-Aftermarket Straight Pipe Exhaust (test pipe back, no downpipe) with Perrin test pipe welded to it - $80 picked up
-FP Speed Density Intake with 8” K&N Filter - $140 shipped
-Speed Density Intake (Brand New) - $160 shipped
-Perrin Recirculating BOV- $180 shipped
-Aftermarket Stock Turbo Intake - $20 shipped
-Aluminum Heat Shield (Custom, fits OEM manifolds or FP manifold) - $40 shipped
IGNITON/FUEL PUMPS/INJECTORS/RAILS:
-Areomotive Fuel Rail - $170 shipped
-Aeromotive FPR with lines - $160 shipped
-Magnecor Ignition Cables - $70 shipped
-(2) Walbro 255 - $50 shipped
-OEM Hanger Modified with a 6AN feed (Missing fuel level) - $50 shipped
GAUGES/ECUS/RADIOS/ELECTRONICS/OEM ELECTRONICS:
-AEM Spec Ops Serial Cable BRAND NEW - $25 shipped
-E85 Flex Fuel Sensor - $80 shipped
-Autometer “Sport Comp” Boost Gauge (45psi) - $40 shipped
-OEM Gauge Cluster (100k miles) - $120 shipped
-Alpine Radio (CDE 110) - $40 shipped
-Kenwood KDC-BT555U with Remote - $30 shipped
-Alpine Front Door Speakers - $50 shipped
SUSPENSION/BRAKES/WHEELS AND TIRES/BRACES/AFTERMARKET AND OEM:
-LIKE NEW Volk RE30, 18x9 +35 with Toyo 265/35/18 (Wheels and Tires only have a few hundred miles) - $2500
-Rota Torques (Light Silver, LIKE NEW) with NT555 245/40/18 (500 miles on them) - $1600
-Velocity Wheels (LIKE NEW with Blue Blox Lugnuts). Sentury Tires 225/40/18 (1000 miles on them) - $700
-PlastiDip Kit for 4 Wheels (One extra can of black as well) ALL BRAND NEW - $45 shipped
-Ichiba 10MM and 5MM Wheel Spacers (All 4, BRAND NEW) - $160 shipped
-Whiteline Rear Sway Bar BRAND NEW - $180 plus shipping
-OEM Aluminum Front Strut Bar (RED) BRAND NEW - $300 plus shipping
-OEM Front Control Arms with Whiteline Bushings and Tie Rod Ends - $360 shipped
-OEM Front Control Arms – $120 shipped each
-OEM Rear Control Arms – PM with what ones you need, have three sets worth
-(2) OEM Front Sway Bar - $80 shipped
-(2) OEM Rear Sway Bar - $80 shipped
-(1 set) Front Knuckles - $120 shipped
-(2 sets) Rear Knuckles - $120 shipped
-(2) Front Subframe - $150 shipped
-(2) Rear Subframe - $150 shipped
-(2) Rear Diff Chassis Mount - $80 shipped
-(2) Power Steering Rack - $150 shipped
-(3 sets) OEM Chassis Braces - OFFER
-(3) OEM Front Strut Bars – OFFER
-(3) Steering Columns with Ignition Switch/Key - $80 shipped each
-(2) Front Rotor Shields - $30 shipped
OEM INTERIOR/SEATS/CONSOLES/TRIM:
-Evo 8 Blue Recaro Pass Front Seat - $150 picked up
-Evo 8 Steering Wheel (No Airbag) - $175 shipped
-Evo 8/9 Trunk Interior - $100 picked up
-OEM Blue Weighted Shift Knob BRAND NEW - $80 shipped
-Evo 9 MR Pedals - $80 shipped
-OEM Center Console (05-06 no sprayer switch) - $60 shipped
-OEM Radio and Climate Control Dash Piece - $25 shipped
-Heater Core - $160 shipped
-(3) Steering Wheel Single Gauge Pod Holder - $30 shipped
-A Pillar Single Gauge Pod (BLACK) - $15 shipped
-(2) Steering Wheel Cover $20 shipped
-(3) Lower Cubby for MR/RS Gauges - $30 shipped
-(2) Glovebox - $40 shipped
-(3) Gauge Cluster Bezel - $25 shipped
-(2) Dimmer Switch - $15 shipped
-Evo 8/9 Interior Pieces (I have a few cars worth) - PM what you need
OEM/AFTERMARKET EXTERIOR PARTS:
-Evo 8 Apex Silver Driver Front Door - $300 picked up
-Evo 8 Apex Silver Driver Side Rear Door (Bend on bottom corner, very small) - $100 picked up
-Evo 9 WW Driver Front Door - $300 picked up
-Evo 9 WW Driver Side Rear Door - $300 picked up
-Evo 9 WW Trunk Lid (Spoiler removed and small dent in back, can be popped out) - $140 picked up
-Evo 9 Front Bumper Lip BRAND NEW (ebay poly) $50 picked up
-Rear Bumper Tarmac Black OEM - $200
-Rear Bumper Weightless White OEM - $200
-Evo 8 Tail Lights (With bulbs and wiring) - $100 shipped
-Evo 8 Tail Lights (No bulbs or wiring) - $60 shipped
-Set of OEM Side Mirror Bolt Covers - $15 shipped
-(8) Clear Side Markers - $8 for a set
-(2) Shorty Antennas - $15 shipped
-Tarmac Black Gas Door - $40 shipped
-Apex Silver Gas Door with Cap - $50 shipped
-Hood Latch - $35 shipped
-(2) OEM Gas Cap - $15 shipped
-Evo 8 Bumper Mesh/Vents – PM what you need
Evo 8/9 OEM PARTS
SENSORS:
-Crank Sensor - $60 shipped
-Exhaust Cam Sensor - $30 shipped
-(3) Knock Sensor - $50 shipped
-(2) Evo (03-04) MAP Sensors - $40 shipped
-(2) Evo (05-06) MAP Sensors - $40 shipped
-(3) Oil Pressure Switches - $15 shipped
-(4) Impact Sensors (Core Support) - $50 shipped
-(2) Airbag Impact Sensor (Inside Car) - $50 shipped
TIMING:
-Box of Like New Timing Components – PM Me
-Evo 9 Gates Timing Belt (10k miles) - $60 shipped
-(3) AC Delete Serpentine Belts - $20 shipped
-(2) LIKE NEW OEM Evo 8 Water Pump (Idle time only) - $80 shipped or best offer
-(3) OEM Serpentine Belt Tensioner - $70 shipped
-(4) OEM Crank Pulley - $60 shipped
-(3) OEM Serp Belt Idler - $30 shipped
OEM EXAUST MANIFOLDS/O2 HOUSINGS/INTAKE MANIFOLDS/THROTTLE BODY:
-(4) OEM Driveshaft in very nice shape - $130 shipped
-OEM Exhaust Manifold - $70 shipped
-OEM O2 Housing with O2 Sensor - $50 shipped
-(4) OEM Intake Manifold - $75 shipped (Three have EGR still and MAP Sensor)
-DSM BOV - $30 shipped
STARTER/ALTERNATOR/WIREHARNESSES/POWER STEERING PUMPS/AC COMPRESSORS:
-OEM Alternator - $90 shipped
-(4) OEM Starter - $90 shipped
-(2) AC Compressors: $130 shipped
-(3) Power Steering Pump without Pulleys - $80 shipped
-Evo 9 Engine Wire Harness - $320 shipped
-Evo 8 Engine Wire Harness - $250 shipped
-Evo 8 Alternator Harness - $70 shipped
-Evo 9 Alternator Harness - $70 shipped
OEM ENGINE PARTS/BRACKETS/ENGINE BAY PARTS:
-Evo 8/9 Rockers – $200 shipped per set
-(2) Evo 8 Oil Filter Housings - $80 shipped
-(4) OEM Cam Gears - OFFER
-OEM Evo 8 Cams – OFFER
-OEM Valve Springs - $40 shipped
-(3) MIVEC Oil Line - $20 shipped
-(3) Oil Dipstick with Tube - $30 shipped
-OEM Motor Mounts (5 Side Engine Mounts, 2 Rear Mounts) – OFFER
-(4) Motor Mount Bracket to Block - $80 shipped
- (3) Master Cylinder - $80 shipped
-Clutch Master Cylinder- $60 shipped
-(3) OEM Clutch Slave - $50 shipped
-Evo 8 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
-(3) Evo 8 Coolant Hard Pipe - $40 shipped
-(2) Evo 9 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
-Evo 9 Coolant Hard Pipe - $40 shipped
-Evo 8/9 Thermostat Housings with Sensors - $60 shipped
-(7) Block to Trans Shield with Starter Hole – $30 shipped
-(2) Flywheel Shields (Under block, bolts into trans) - $25 shipped
-(7) AC Compressor Bracket - $25 shipped
-(2) Power Steering Pump Bracket (One has crack in bolt hole, nothing crazy) - $35 shipped
-(3) Coolant Reservoir - $25 shipped
-(2) Power Steering Reservoir - $25 shipped
-Power Steering Cooler Line - $120 shipped
-OEM Battery Tray (Missing top bracket) - $30 shipped
-(3) Hood Prop - $20 shipped
-Front Windshield Wiper Motor - $30 shipped
-(2) ABS Module – OFFER
-(2) Evo 8/9 Injector Resistor Pack/Bracket - $40 shipped
-Evo 8 OEM Spark Plug Cover - $20 shipped
-(3) Evo 8/9 Horns - $10 shipped
OEM IGNITION/FUEL/RADIATORS/FANS/PIPING/MODULES/AC LINES:
-OEM Fuel Tank (Southern car, tank is perfect) - $150 picked up
-OEM Evo 8/9 Ignition Coils - $70 shipped
-(2) OEM Fuel Rail/FPR - $45 shipped
-(2) OEM Fuel Rail - $30 shipped
-OEM Radiator - $120 shipped
-Radiator Fan/Shroud/Module - $80 shipped
-(3) Radiator Fan/Shroud no Module - $50 shipped
-Radiator Fan Module - $40 shipped
-(3) AC Condenser Fans (Have one single fan if interested) - $60 shipped
-(5) OEM Upper Radiator Pipes - $20 shipped
-(10) OEM Lower Radiator Pipes - $20 shipped
-(6 sets) OEM Radiator Upper Mounts – $15 shipped per set
-Tons of AC Lines (Lmk what you need) - OFFER
SOLD:
-Fluidampr Crank Pulley
-OMNI 4Bar MAP Sensor
-Evo 8 Brian Crower 280/280 Cams
-ARP L19 Headstuds
-Evo 9 Oil Cooler (Came from a good engine)
-Buschur Mustache Bar and Billet Diff Mounts (Comes with all of the hardware)
-Exedy Tripe Disc Clutch GREAT SHAPE (Discs measure 3.70-3.80)
-ACT HDSS Clutch Kit (7k miles)
-ETS 4” FMIC LIKE NEW (2k miles)
-ETS UICP with Blue Tial (Pipe is powdercoated dark green, see pics)
-DNP Coated Tubular Manifold (2k miles)
-FIC 2150s with PnP adatpers and Resistor Pack Delete Plug (2k miles)
-Buschur Racing Double Pumper and Braided Fuel Lines from Engine Bay to Tank with Filter as well (2k miles)
-Walbro 450 (Dyno time only)
-AMS Fuel Rail (Blue)
-Braided Fuel Lines with Filter (Engine Bay to Fuel Tank)
-AEM Digital Tru-Boost BRAND NEW
-AEM A/F Gauge (Silver Bezel/White Face)
-Prosport Oil Pressure Gauge
-OEM Gauge Cluster (154k miles)
-Blitz Turbo Timer
-Swift Lowering Springs Spec R (Bilsteins) BRAND NEW
-OEM Climate Control Box
-Steering Wheel Double Gauge Pod Holder
-Evo 9 Front Bumper White GREAT SHAPE (Brackets and mesh pieces are included but no installed on bumper)
-Evo 8/9 Apex Silver Front Radiator Core Support (Cut at Strut Towers)
-Evo 8/9 Apex Silver Hood (Very Nice Shape)
-Evo 8 HID Headlight
-Evo 8 WW Passenger Fender
-Evo 8 Apex Silver Driver Fender
-Evo 9 WW GSR Front Lip Great Condition
-Evo 8 Timing Belt (Like New)
-OEM Intake Manifold
-Power Steering Pump
-OEM Evo 8 Cams
-Braided Clutch Line with Clutch Slave Cylinder
-MAP Clutch Slave Stopper
-Evo 8 Lower Timing Cover
-OEM Battery Tray
-(2) OEM Evo 560cc Injectors
-Evo 8 Valve Cover 6/10 shape (Has AN Fittings and Lines with it)
-TRE Stage 3 Trans, 4.11 Final (2k miles and just gone through Jon at TRE a few months ago, maybe a few hundred miles since that)
-Shep Tcase with Wavetrac (2k miles)
-Evo 8 Transmission 93k miles
-ACT HDSS Clutch Kit with ACT Flywheel (10k miles)
-Competition Clutch Kit Stage 3 (Monoloc included) with Comp Lightweight Flywheel (5k miles)
-Samco Upper Radiator Hose Blue (With blue overflow line)
-STM Lightweight Ultra Quiet Resonator BRAND NEW
-Tial BOV VTA (Blue)
-FiTronic Flex Fuel Tuning System
-Autometer “Pro Comp” Oil Pressure (0-100) and Boost Gauge (30psi) White Face
-Brembos Front and Rear (Painted Silver)
-Braided Brake Lines (ALL 4)
-Buschur Racing Lightweight Cross Member (2k miles)
-Evo 8 Blue Recaros Fronts with Bottom Rear Seat
-3 Pod Gauge Pod Holder for Dash
-IAC Sensor
-Brand New Exhaust Cam Sensor
-Crank Pulley
-Stock Turbo Intake
-ACD PUMP GREAT SHAPE (70k miles. Missing solenoid)
-STM FP Turbo Downpipe
-MAP FP Turbo Downpipe
2006 WW IX RS 396/404 - SOLD
