Old 10-05-2017   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Evotuna's Fall Partout
Evo 8/9 Evo Partout:
We’ve had 33 Evos come through the doors in the past few years, tons of parts available. They go fast but there’s always something new getting added.
EVERYTHING IS IN GOOD-GREAT WORKING CONDITION UNLESS STATED OTHERWISE.
-Located in Mankato, MN 56001
-Phone # 507-215-2103. Texting is preferred
-Chris
PICTURES ARE BELOW THIS POST
ENGINE:
-Evo 9 Stock 2.0 Longblock Oil Pan to Valve Cover (No Manifolds or Turbo) - $4000 shipped
-Evo 8 Built 2.0 Longblock (Wiseco 1400HD Pistons, Manley H Beam Rods, Stock Crank, H11 Headstuds. Low mile BRAND NEW stock head before being pulled.) - $4200 shipped
-Evo 8 Bare 2.0 Block with Girdle (Bored .020 over, spun bearing would need a line hone and some machine work) - $200 picked up or plus shipping via freight.
-BNIB Curt Brown Evo 9 Cylinder Head (Ported and Fully Built PM for more details) - $2000 shipped
-BNIB Evo 9 Cylinder Head Complete Ready to Drop In (Rebuilt by MAP) - $1600 shipped
-MAP H11 Headstuds (Torques Once, Great shape) - $140 shipped
-(2) OEM Oil Cooler with Lines (Great shape) - $150 shipped
-OEM Oil Cooler Lines (Great shape) - 80 shipped
-Aluminum “Evolution” Spark Plug Cover with Hardware - $70 shipped
-K&N Valve Cover Breather Filter - $10 shipped
TRANS/TCASE/DIFF/DIFF PARTS/ACD PUMPS/AXLES/CLUTCHES/FLYWHEEL/CLUTCH LINES:
-OEM ACD Tcase (72k miles GREAT condition) - $1200 shipped
-OEM ACD Tcase (78k miles, Great condition) - $1200 shipped
-OEM ACD Tcase (89k miles, Great Condition) - $1150 shipped
-OEM ACD Tcase (Whines, recommended rebuild) - $650 shipped
-(2) Transmission Inner Axle (Driver side) - $30 shipped
-(6) Transfer Case Inner Axle (Passenger side) - $30 shipped
-OEM Rear Diff (Great condition) - $800 shipped
-OEM Rear Diff (Needs Rebuild) - $400 shipped
-ACD Pump Complete Unit (Great condition) - $450 shipped
-ACD Pump (Needs new solenoid, knocked off during accident. Great condition and low miles.) - $300 shipped
-ACD Parts – PM me for details
-(2) ACD Pump Brackets - $60 shipped
Axles/Clutches/Flywheels/Clutch Lines:
-OEM Front Axles - $280 shipped for a set or $140 each (3 FL, 2 FR)
-OEM Rear Axles - $280 shipped for a set or $140 each (1 set)
-AWD Motorsports Aluminum Driveshaft w/Beatrush Solid Bushings (LIKE NEW) - $800 shipped
-(5) OEM Driveshaft in very nice shape - $130 shipped or $60 picked up
-ACT 6 Puck Clutch (1500 miles, LIKE NEW with ACT Monoloc - $420 shipped
-ACT HDSS Pressure Plate (You’ll need a disc to make it complete, discs are about $130 new) - $120 shipped
-OEM Evo X Pressure Plate GREAT SHAPE (Needs New Disc) - $120 shipped
-ACT Streelite Flywheel (Great Shape) - $140 shipped
-ACT Flywheel - $100 shipped
-OEM Flywheel (Resurfaced 1500 miles ago, GREAT Condition) - $120 shipped
-STM Full Stainless Clutch Line – Master to Slave (BRAND NEW) - $50 shipped
-(3) Braided Clutch Line (Half Line) - $20 shipped
TURBOS/WASTEGATES/BOOST CONTROL/FMIC/PIPING/MINI BATTERY/RADIATOR/COOLING:
-FP Green Turbo and FP 18PSI Wastegate (Complete, old school, in great shape) - $650 shipped
-(2) Evo 9 Turbo with Wastegate - $425 shipped
-Aftermarket Evo 9 Wastegate (Great condition) - $30 shipped
-Evo 8/9 Turbo Coolant/Oil Lines/Return Lines -PM what you need, tons of stuff here
-FP 4AN Red Oil Restrictor with Line - $40 shipped
-FP 4AN Black Oil Restrictor - $20 shipped
-MAC Electronic Boost Controller - $25 shipped
-Hallman MBC (Purple) - $40 shipped
-(3) OEM Boost Control Solenoids - $25 shipped
Piping:
-AMS LICP - $80 shipped
-OEM Evo 8 UICP - $80 shipped
-OEM Evo 9 UICP - $80 shipped
Battery:
-Shorai Lithium Battery LFX36A3-BS12 & Shorai Charger SHO-BMS01 (ALL BRAND NEW) - $220 shipped
-Custom MP Fab Aluminum Battery Tray for above battery (BRAND NEW) - $150 shipped
Radiator:
-Megan Racing Radiator with Slim Fan - $140 shipped
-OEM Radiator Fan NO MODULE - $50 shipped
-Samco Radiator Hoses Blue (4/5/6) BRAND NEW - $60 shipped
-(7) OEM Upper Radiator Pipes - $20 shipped
-(11) OEM Lower Radiator Pipes - $20 shipped
-(14) Lower Radiator Bushings - $10 for a set shipped
-OEM Radiator Upper Mounts – $15 shipped per set
EXHAUST/EXHAUST MANIFOLDS/O2 HOUSINGS/SHIELDS
-MP Fab 3” Aluminum Exhaust (BRAND NEW, AMAZING KIT) - $1000 shipped or best offer
-FP Exhaust Manifold (Great condition) - $220 shipped
-Megan Test Pipe Back Exhaust “Burnt Tip” - $60 picked up
-Test Pipe Back Exhaust - $40 picked up
-No Name 3” Downpipe - $50 plus shipping
-OEM Downpipe - $75 plus shipping
-(4) OEM Exhaust Manifold - $60 shipped
-(2) OEM O2 Housings - $25 shipped
-OEM Exhaust Manifold Heatshield - $30 shipped
-(2) O2 Housing Heatshields - $20 shipped
INTAKES/MAFs/BOVS/SPEED DENSITY/INTAKE MANIFOLDS/THROTTLE BODY:
-FP Silicone Recirculated Intake Pipe (For 84mm Compressor Cover, LIKE NEW) - $80 shipped
-Custom FP SD Intake with K&N Filter (VERY NICE SHAPE) - $70 shipped
-HKS Intake Pipe - $50 shipped
-Aftermarket Stock Turbo Intake - $25 shipped
-(3) OEM Intakes - $25 shipped
MAFs/BOV/Speed Density Parts/ Other Intake Parts:
-(3) OEM MAFs - $50 shipped
-OEM Evo 9 Metal BOV - $75 shipped
-(2) AIT Harness - $10 shipped
-(3) Fuel Injector Resistor Bypass Plug - $10 shipped
-OEM Ram Air Vents to Air Box - $50 shipped
Intake Manifold/Throttle Body:
-(5) OEM Intake Manifold - $75 shipped
FUEL PUMPS/INJECTORS/RAILS/IGNITION/EVAP SYSTEMS/FUEL TANK:
-Walbro 450 with Customized OEM Hanger (2k miles, GREAT SHAPE) - $180 shipped
-PTE 1000cc Injectors - $200 shipped
-6AN Braided Line (2’ Long) - $20 shipped
-Fuel Lab Pressure Gauge BRAND NEW - $20 shipped
-OEM Evo 8/9 Ignition Coils - $70 shipped
-OEM Fuel Rail with 6AN Fitting - $40 shipped
-(1) OEM Fuel Rail/FPR - $40 shipped
-(4) OEM Fuel Rail - $30 shipped
-(3) OEM Fuel Line From Rail to Hard Line - $30 shipped
-(2) EVAP Cannister - $200 shipped
-Fuel Tank (GREAT SHAPE) - $100 picked up or plus freight shipping
-EGR Parts – PM me for pricing, tons of EGR stuff here in storage bins
STARTER/ALTERNATOR/POWER STEERING PUMPS/AC COMPRESSORS/WIRE HARNESSES:
-(5) OEM Starters - $90 shipped
-OEM Alternators - $90 shipped
-(1) Power Steering Pump - $120 shipped
-(2) AC Compressor - $120 shipped
Wire Harnesses:
-Evo 9 Engine Harness - $300 shipped
-Evo 9 Transmission Harness- $75 shipped
-Evo 8 Alternator Harness - $70 shipped
-Evo 9 Alternator Harness - $70 shipped
-(2) Fuel Tank Harness - $40 shipped
-Evo 9 NON HID Driveside Headlight Harness with Fuse Box, Battery Wiring, Hood Prop/Cable, Throttle Cable, Radiator Fan Wiring ETC. - $150 shipped
-Evo 9 NON HID Passenger Headlight Harness with ABS and Airbag Wiring - $80 shipped
-Evo 8/9 LH Taillight Harness - $70 shipped
-Evo 8/9 RH Taillight Harness - $70 shipped
SUSPENSION/BRAKES/BRACES/AFTERMARKET AND OEM:
Struts:
-KYB Struts with Tein Lowering Springs (Great shape, no rust) - $425 shipped
-KYB Struts with Swift Spec R Lowering Springs (AMAZING SHAPE NO RUST) - $540 shipped
Brakes:
-STM Staging Brake Full Kit (BRAND NEW) - $460 shipped
-Whalen’s Speed R&D Power Steering Line and Reservoir Kit (BRAND NEW) - $200 shipped
-Brembo Front and Rear Calipers Complete - $520 shipped
-Brembo Front Calipers Complete with Pads (Black in color, good condition, faded paint) - $320 shipped
-Rotor Pros Front and Rear Rotors (Great Shape) - $160 picked up
-Rotor Pros Front Rotors (Great Shape) - $100 picked up
-(3) Front sets of Rotors - $60 each set picked up
-(3) Rear sets of Rotors - $40 each set picked up
-Ebrake Drum/Dust Shield (RL)- $40 shipped
-Ebrake Cables - $70 shipped
-(5) Front Driver Rotor Shields - $30 shipped
-(2) Front Passenger Rotor Shield - $30 shipped
-(2) Brake Booster - $70 shipped
Sway Bars/Control Arms:
-BWR Billet Rear Lower Control Arms (BLACK IN COLOR, BRAND NEW) - $275 shipped
-Whiteline 24MM Rear Sway Bar BRAND NEW - $160 plus shipping
-Tanabe Front Sway Bar w/ New Whiteline Bushings - $250 shipped
-Perrin Rear Sway Bar Endlinks (BRAND NEW) - $110 shipped
-Torque Solutions Diff Bushing Kit (BRAND NEW) - $50 shipped
-Energy Bushing (Set incomplete PM me) - $30 shipped
-OEM Front Control Arms – $120 shipped each (1 Passenger in stock)
-OEM Rear Control Arms (4 LCAs, 4 Lateral Toe Arms, 4 RH Trailing Arms, 3 LH Trailing Arms, 5 RH Upper Arms, 3 LH Upper Arms IN STOCK) – PM for pricing please thanks!
-(2) OEM Front Sway Bar - $40 plus shipping
-OEM Rear Sway Bar - $40 plus shipping
Subframes/Knuckles/Ebrake/Strut Bars/Braces/ETC:
-Front Cross Member with AMS Front Motor Mount - $100 shipped
-(2) OEM Front Cross Member with Stock Front Mounts - $75 shipped
-Front Spindles/Knuckles – 2 FL, 1 with ABS Sensor. 2 FR, 1 with ABS Sensor- PM for pricing
-Rear Spindles/Knuckles – 4 RL, 1 with ABS Sensor/Ebrake Drum. 3 RR, 2 with ABS Sensor – PM for pricing
-OEM Aluminum Rear Diff Mount - $80 shipped
-Front Subframe - $175 shipped
-(2) Rear Subframe - $175 shipped
-OEM Chassis Braces (Side to side ones that mount under exhaust/subframe. 3 Short, 5 Long) – PM me for pricing
-(4) OEM Front Strut Bars – OFFER
-Aftermarket Rear Strut Bar (Great shape and lightweight) - $80 shipped
-(3) Steering Columns with Ignition Switch/Key - $100 shipped each
WHEELS/TIRES/LUGNUTS:
Wheels: PM for shipping quotes!
-(4) Enkei GTC 01 Wheels 18x9.5 with Bridgestone Potenza RE760 tires 265/35/18. 7/32nds (Great shape wheels and tires) - $1000 picked up
-(4) Evo 8 Enkeis 17x8 with Arctic Claw Winter TXi M+S (225-45/17, 9/32nds). Tires are like new, wheels are in fair shape, black in color - $400 picked up
-(4) Evo X Enkei Wheels 18x8.5 (Came from a 2015 Evo X, very good shape) - $500 picked up
-(4) Evo 9 Enkei Wheels 17x8 (Fair shape, good candidate for powder coat or dipping) - $300 picked up
-(4) Rota Torque Wheels 17x8 (Light Silver, LIKE NEW) - $450 picked up
-(4) Enkei Raijns Wheels 18x9.5 +15 offset (Two are in very good shape and two were very road rashed and one was bent) - $100 picked up
Tires: PM for shipping quotes!
-(4) Hankook Ventus V12 Evo Tires 255/40/17 (500 miles on them LIKE NEW) - $400 picked up
-(4) Bridgestone Blizzak LM-25V 245/45/17 (LIKE NEW (10/32s) - $500 picked up
-(4) Bridgestone Potenza RE71 255/40/18 (Very very good shape 6-7/32nds) - $650 picked up
-(2) Bridgestone Potenza RE71 265/35/18 (Have a few track days left 4/32nds) - $100 picked up
-(2) Bridgestone Blizzaks 265/35/18 (LIKE NEW 10/32nds) - $200 picked up
Lugnuts:
-Fortune Auto Titanium Lugnuts LIGHT BLUE, GREAT SHAPE! (All 20 included) - $80 shipped
GAUGES/ECUS/RADIOS/ELECTRONICS/TURBO TIMERS/OEM ELECTRONICS:
-(3) Evo 9 ECU’s - $165 shipped
-Gauge Cluster ACD (72k) - $150 shipped
-Gauge Cluster ACD (125k) - $120 shipped
-Gauge Cluster ACD (113k) $120 shipped
-MR Gauges (NO wiring) - $30 shipped
-ACD ECU - $40 shipped
-HKS Turbo Timer - $20 shipped
-Alpine 8” Double DIN (INE-Z928HD, Comes with speaker wiring, and XM extras) - $700 shipped
-Alpine Radio (CDA-9886 with wiring) - $30 shipped
-Alpine Radio (CDA-9856 with wiring) - $30 shipped
-Clifford G5 Intelliguard 770 Alarm - $30 shipped
-Foval 300W Power Inverter - $12 shipped
OEM SEATS/STEERING WHEELS/INTERIOR/CONSOLES/CARPET/DASH/TRIM:
Seats/Steering Wheels:
-NRG Carbon Fiber Seats BRAND NEW - $800 picked up or can ship via Freight
-(2 sets) Evo 9 Recaros Front and Rears (Great Shape) - $800 picked up either set or can ship via Freight
-Evo 9 Recaros Front Seats (Good condition, has one cigarette burn hole on ass cushion) - $700 picked up or can ship via Freight
-Evo 8 Blue Recaros Front and Rears (Nice shape) - $400 picked up or can ship via Freight
-Evo 9 Steering Wheel with Airbag (GREAT CONDITION) -$280 shipped
-Evo 9 Steering Wheel NO Airbag (GREAT CONDITION) $215 shipped
-Evo 8 Steering Wheel with Airbag (GREAT CONDITION) - $240 shipped
Interior:
-Evo 9 Carbon Fiber Dash Pieces (AMAZING SHAPE) - $240 shipped or $200 picked up
-5 Speed Shifter Base/Lever with Cables - $160 shipped
-MR Pedals/Whole Assembly - $100 shipped
-(2) OEM Silver Weighted Shift Knob - $40 shipped
-OEM Black Leather Shift Knob - $20 shipped
-(2) Evo 8/9 Radio/Climate Control Surround - $30 shipped
-Evo 8/9 Double Din Dash Piece w/HVAC Relocation - $50 shipped
-Double DIN Dash Piece - $30 shipped
-(3) Steering Wheel Single Gauge Pod Holder - $30 shipped
-A Pillar Single Gauge Pod (BLACK) - $15 shipped
-(3) Lower Cubby for MR/RS Gauges - $40 shipped
-RS Center Console - $40 shipped
-MR/GSR/SE Center Console (With Arm Rest GREAT CONDITION) - $70 shipped
-(2) 5speed Shifter Consoles - $50 shipped
-Shifter Console Cover - $35 shipped
-(2) Evo 8 Long Dash Pieces (Where clock sits in between air vents) - $60 shipped
-(3) Glovebox - $40 shipped
-(1) Sun Visor (Driver Side) - $20 shipped or $30 for a set
-(3) Sun Visor (Passenger Side) - $20 shipped or $30 for a set
-(2) Rearview Mirror - $20 shipped
-Gauge Cluster Dimmer Switch - $20 shipped
-Headlight Dimmer Switch - $12 shipped
-Mirror Control Switch - $12 shipped
-Fog Light Switch - $12 shipped
-ACD Switch - $12 shipped
-(3) Cigarette Lighter - $10 shipped
-OEM Ebrake and Base - $30 shipped
-OEM Ebrake Handle (Handle Only) - $12 shipped
-2005 Evo Owner’s Manual and Case (Nice shape) - $30 shipped
-2006 Evo Manual (Only has Maintenance/Warranty Brochure) - $10 shipped
Carpet:
-Floor Carpet (GREAT SHAPE) - $100 plus shipping
-(2) Evo 9 Rear Seat Sound Deadening Mat - $40 shipped
Dash:
-(2) Dash (Airbags did NOT deploy) - $150 picked up or plus freight shipping
-Dash Harness/Bar (Uncut, GREAT SHAPE) - $150 picked up or plus shipping
Heater Core/Spare Jack/OTHER Interior Pieces:
-(3) Heater Core Full Assemblies - $50 plus shipping
-(2) OEM Emergency Jack Kit For Spare Wheel - $40 shipped
-Evo 8/9 Interior Pieces (I have about 5 cars worth) - PM what you need
OEM/AFTERMARKET EXTERIOR PARTS/BODY PANELS:
Headlights/Taillights:
-Evo 9 Headlights HID (Converted from NON HID, Really nice shape) - $800 shipped
-Evo 8/9 HID Ballast Great Shape - $60 shipped
-Evo 8 Taillights (Housing painted black, looks really nice) - $140 shipped
Body Panels:
-Evo 9 WW Hood with Mesh and Vent - $400 picked up
-Evo 8/9 Front End Clip WW In Color (Strut cut, very nice shape) - $400 picked up
-Evo 8 Rally Red Driverside Doors (Nice Shape) - $200 each pick up
-Evo 8 Rally Red Passenger Front Door - $200 picked up
-Evo 8 Rally Red Driverside Fender - $120 picked up
-Evo 8 Rally Red Wingless Trunk (Has spoiler holes) - $100 picked up
-Evo 8 Rally Red USDM Rear Bumper - $100 picked up
-Evo 8 Rally Red Sideskirts (Good shape and both sides) - $50 each picked up
Exterior Parts, Odds and Ends:
-(2) Rear Bumper License Plate Bar/Bracket and Wiring - $70 shipped
-Rear Bumper License Plate Bar/Bracket NO WIRING - $50 shipped
-(2) Roof Weather Strip Moldings Pair - $80 picked up
-1 LH Side/Fender Mirror Covers - $20 shipped
-3 RH Side/Fender Mirror Covers - $20 shipped
-Apex Silver Gas Door with Cap - $50 shipped
-WW Gas Door with Cap - $50 shipped
-Rally Red Gas Door with Cap - $50 shipped
-Evo 8 Front Bumper Mitsubishi Emblem BLACK - $15 shipped
-NEW Mitsubishi Trunk Emblem - $20 shipped
-(A set) Evo 8/9 Apex Silver Hood Brackets by Strut Towers - $40 shipped
-(A set) Evo 8/9 WW Hood Brackets by Strut Towers - $40 shipped
-(3) Driver Windshield Wiper Arm - $30 each, $35 with blade
-(2) Passenger Windshield Wiper Arm - $30 each, $35 with blade
-(2) Windshield Wiper Bolt Covers - $12 shipped per set
-(3) LH Windshield Wiper Cowls - $40 shipped or $70 for a set
-(4) RH Windshield Wiper Cowls - $40 shipped or $70 for a set
-(10 and 1 Blacked out) Clear Side Markers - $20 for a set shipped, $15 each shipped
-(2) Hood Latch - $25 shipped
-(3) Hood Prop - $20 shipped
-(2) OEM Gas Cap - $15 shipped
-Trunk Weather Strip Molding - $25 shipped
-Evo 8 Bumper Mesh/Vents – PM what you need
-LH Rear Quarter Splash Guard - $30 shipped
-(2) RH Rear Quarter Splash Guard - $30 shipped
-(2) Splash Guards EVAP Cannister - $25 shipped
-(2) Shield for EVAP Cannister Lines - $15 shipped
Evo 8/9 OEM PARTS
-I will leave a number next to the corresponding part to show how many I have in stock on everything below.
OEM BRAND NEW PARTS:
-(1) Mivec Cam Gear - $300 shipped
-(1) Evo 9 Coolant Water Pipe - $80 shipped
SENSORS:
-(2) TPS Sensor - $75 shipped
-(1) IAC Ebay Brand, BRAND NEW) - $30 shipped
-(4) Crank Sensor - $50 shipped
-(5) Knock Sensor - $40 shipped
-(5) Evo (03-04) MAP Sensors - $25 shipped
-(3) Evo (05-06) MAP Sensors - $25 shipped
-(1) Thermostat Water Temperature Sensor - $25 shipped
-(1) Thermostat Water Temp Gauge Sensor - $15 shipped
-(4) Front O2 Sensor - $50 shipped
-(3) Rear O2 Sensor - $30 shipped
-(4) Impact Sensors (Core Support) - $40 shipped
-(2) Airbag Module - $30 shipped
-(2) Airbag Impact Sensor (Inside Car) - $20 shipped
AC FANS/AC LINES:
-(3) AC Condenser Fans - $60 shipped
-(2) Condenser Fan ONLY- $30 shipped
-Tons of AC Lines – PM what you need
TIMING:
-Tons of Timing Components – PM Me
-(1) Evo 8 Upper Timing Cover - $35 shipped
-(3) Lower Timing Covers - $40 shipped
-(3) OEM Cam Gears - OFFER
-(4) Evo 8 Water Pumps (LIKE NEW, very low miles) - $50 shipped
-(1) Evo 9 Gates Timing Belt (6k miles GREAT SHAPE) - $40 shipped
-(1) Evo 9 OEM Timing Belt (5k miles GREAT SHAPE) - $30 shipped
-(4) OEM Serpentine Belt Tensioner - $70 shipped
-(6) OEM Crank Pulley - $60 shipped
-(7) Water Pump Pulley - $20 shipped
-(5) OEM Serp Belt Idler - $30 shipped
-(3) AC Delete Serpentine Belt - $25 shipped
-(3) OEM Serpentine Belts - $25 shipped
OEM ENGINE PARTS/BRACKETS/ENGINE BAY PARTS:
-Box of Front and Rear End Bolts (Diff, F&R Subframes ETC) - $100 shipped
-(1) OEM Evo 9 Cams - $60 shipped
-(3) Evo 9 Rods/Pistons/Squirters - $50 shipped
-(1) Evo 9 Oil Filter Housing - $40 shipped
-(1) OEM Valve Springs - $30 shipped
-(1) OEM Balance Shaft Set - $25 shipped
-(4) MIVEC Oil Line - $20 shipped
-(1) Oil Pickup Plate - $15 shipped
-(3) Oil Dipstick with Tube - $30 shipped
-(1) Dipstick - $18 shipped
-OEM Motor Mounts (7 Pass Side Mounts, 5 Rear Mount, 2 5Spd Trans Mount, 1 Front ) – PM Me
-(5) Motor Mount Bracket to Block (3 Studs for Pass Side Motor Mount) - $70 shipped
-(1) Subframe Mount for Rear Motor Mount - $15 shipped
-(5) Master Cylinder - $50 shipped
-(3) Clutch Master Cylinder- $50 shipped
-(6) OEM Clutch Slave - $30 shipped
-(2) Evo 8 Coolant Hard Pipe - $50 shipped
-(3) Evo 9 Coolant Hard Pipe - $40 shipped
-(1) Evo 9 Thermostat Housings with Sensors - $60 shipped
-(10) Block to Trans Shield with Starter Hole – $30 shipped
-(5) Flywheel Shields (Under block, bolts into trans) - $25 shipped
-(8) AC Compressor Bracket - $20 shipped
-(1) PS Pump Bracket - $30 shipped
-(1) Oil Cooler Brackets - $35 shipped
-(5) OEM Battery Trays - $30 shipped
-(4) Coolant Reservoir - $25 shipped
-(2) Power Steering Reservoir - $25 shipped
-(2) Power Steering Cooler Line - $120 shipped
-(4) Front Windshield Wiper Motor - $30 shipped
-(3) Injector Resistor Modules/Bracket - $30 shipped
-Throttle Cable - $15 shipped
-(4) Evo 8/9 Horns - $10 shipped
-(1) Hella Horn - $14 shipped
-(1) Windshield Washer Tank for FMIC Spray - $40 shipped
-(1) Fusebox Cover - $15 shipped
2006 WW IX RS 396/404 - SOLD
