Old 03-05-2018   #1
Advice needed....
So some of you know my red car is at a shop having the motor rebuilt.
I also want them to put. Cage in it, my subframe bushings, diff mounts, my bobby g. suspension, sway bars and , comp work fender braces.
None of which has been started yet.
And the initial guestimate quote for prepping the car, the cage and spare tire delete. Is $3600.
I still have to pay for everything else to be taken out parts installed and then reinstalled.
So that leads me to this shell that's available with delivery. $3500
Why shouldn't I just reinstall my parts from my red car to this one since most of its coming off anyways.
Thoughts?
ID:	16913   Click image for larger version
ID:	16914   Click image for larger version
ID:	16916   Click image for larger version
Old 03-06-2018   #2
Re: Advice needed....
My guess is a labor quote to swap EVERYTHING over to a new chassis will be quite a bit higher than your initial thoughts, but that's just my guess. BUT, it would also leave you with a bare red (stock?) chassis to sell after the fact...
Old 03-08-2018   #3
Well went ahead and made the deposit on the shell. Jusy have to finalize / find shipping down here. Spent more but got a whole lot more.
Old 03-09-2018   #4
Dark2g
Drives: 2gb gsx
Is the guy that had the car the same size as you or how do you know you will fit in the car with how it was built? I know you were concerned before when you made a previous post in your thread.
Old 03-09-2018   #5
Agree. You want to be sure you fit inside the cage. Don't want your helmet above the hoop. Guess you could always just mount the seat as low as possible if that's the case.
Old 03-10-2018   #6
Honestly. Not sure about his size.
BUT he already did all the mods I was going to do to my red car to try and lower the seats.. so either way if I don't fit the next step will have to be lowering the floor, or removing the sunroof and going with a carbonfiber one.
Ill cross that road once it gets here. I hate speculating stuff. I'm just to the point of taking everything one step/obsticle at a time. In the end regardless, what ever needs to get done will just get done, may take time bit that's just how it goes with modding cars.. you all know the deal.
Old 03-10-2018   #7
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
It just seams right that you will have a White car again.
11.35 @ 120mph
Old 03-10-2018   #8
Lol it does. I wanted one from the get go and was going to at somepoint paint my car white.
This just saved me so much time and money in my eyes. And I know Steve made the comment in my red car "at least no body kit"
Well for now.. but my end goal is an AB road racing kit at some point... so that'll really be like old times..
I plan on getting a custom plate for this one.
"SLOWHT2"
Old 03-10-2018   #9
White is right!
Old 03-11-2018   #10
Well it's a go. Car Is Getting Picked Up Next friday. And then headed to Spartanburg the weekend after that.
Hopefully this will speed the entire process of what would have been a year of build time with my red car.
I no longer have to have the cage built, spare tire well removed and sheet metal installed, Compworks fenders braces don't need to be installed, custom seat mounts currently don't need to done as everything that's known to lower seats has been done already.
Has the brembro exo 9 brakes all around. He lowered his price on rims and tires by $400 so I bought those now as well.
Fuse box relocated to the airbag.
And best of all... its WHITE
