Old 03-13-2018   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Engine and Transmission
*******Built 6 Bolt DSM for sale******** $2200
-.20 Over 6 Bolt Block
Wiesco HD Piston's 8.5:1
Crower Rods
ACL Main Bearings
ACL Race series Tri Metal Rod bearings
ARP Main Studs
ARP Rod Bolts
Cometic Tripple layer headgasket
Crankshaft machine balanced to 10,000RPM
Straight Cut gear Driven Oil Pump with new Front Cover
External Oil Cooler OFH
6 Bolt Big Port Cylinder Head
1mm over size valves
BC Valve Springs
Brian Crower 280 Camms (Propperly Degreed in with AEM Tru Time Adjustable cam gears)
MAP H11 Headstuds
Gates Race Series Kevelar Timing Belt
New Hydraulic Tension-er
New idler and Tension-er pulley
**********1G Evo 3 Ultimate ratio Gear set transmission with 5th gear delete and shift rail mod (5th gear and none modified shift rails will be included inccase you want to add 5th gear back)******** $1800
-EVO III 1st - 4th Gears with 'Tighter Gear Ratios'
Latest Revision All Bronze Synchros (Forward Gears) replaced during last disassemble in anticipation of 2017 race season
3-4 Shift Fork Upgrade
New Intermediate and Input Shafts (at time of purchase couple seasons old now)
Large Double Synchro 1st & 2nd Gears
EVO III Double Synchro 3rd & 4th Gears
Thanks,
David
ID:	16945   Click image for larger version
ID:	16946   Click image for larger version
ID:	16948   Click image for larger version
ID:	16949   Click image for larger version
Old 03-13-2018   #2
Archertsi
Archertsi's Avatar
Drives: 1995 talon tsi
Re: Engine and Transmission
1g trans?
Horsepower costs money, how fast can you afford to go?
@BloodSweatMotorwerks
Archertsi is offline   Reply With Quote
Old 03-13-2018   #3
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Yes, 1G transmission. Sorry i should have specified for which model.
