Old 07-18-2018   #1
CarPsyco84
CarPsyco84's Avatar
FS: 1g 600ish whp awd part out
So sawing my motor in half was the last straw. I am getting out of dsm's and moving on to bigger and better things. My failures are your boon's. I have a multitude of parts that need to go to good homes. Prices are all OBO.
First stuff is almost brand new, only a couple hundred miles on this:
2150cc Hi-Z FIC injectors have the data sheet/link info/plug&play -sold
Fluidamper, still have the box and the certs -sold
FuelLab 81831-1 black, 6 micron fiberglass -sold
Zaklee Clear timing belt cover -sold
Freshly reworked bolt-on O2 w/tial 38mm, has a 3" marmon flange? -sold
Southbend SS-X clutch kit 6puck un-spring clutch disk with (2700 lb) pressure plate, - $200 dropped
***This stuff has approx 1k miles in like new condition
ETS race 4" Intercooler back door -sold
FP Black with ported exhaust housing journal bearing (will come with water and oil lines everything to bolt up -sold
FP 4" cast intake tube/filter, no extra lines to it, could add some if desired - $50 - dropped
17" x 9" +45 Bronze Enkei RPF1's with 255/40/17 ZII star spec's, barley worse the nubs off the tires, wheels were brand new when I got them. Can give you the spacers I ran to make them fit a 1g if desired. -$1400 - dropped
***Other used items:
Muellerized JiC's absolutely awsome on these cars and no longer available. - sold
Shep stage 3 w/4 spider 91-94 AWD trans. Always ran the OEM evo 6spd fluid. -sold
REEF street intake (handmade prototype only 3 or 4 exist better than the others) - sold
ACT street light flywheel $50 - dropped
23 Spline Transfer cases $100 (got 2)
22 spline Transfer case (alum headed one) $80 - dropped
L19's -sold
External Oil cooler set up with push lock lines (comes with ported ofh and everything else to make it work) -sold
3.5” catback ss exhaust with magnaflow muffler $125 - dropped
Carbon Hood w/Vent $100
New to list:
ARC-2 Box with plug and play wiring kit and bracket $200
6 bolt head with Evo beehive valve springs and retainers and BC280s $350
I havea stock 6 bolt heads $100
ACE 140 Amp Alternator, has 100 miles on it $60
1G green top CAS $40
1G coil with block bracket I rewired the power wire with larger wire to lower the resistance to the primary $40
1G ignition coils (got 2 more) $20
Got a bunch of other odds and ends as well, like, couplers, water cooled OFH, couple stock 6 bolt oil pans.
Free stuff:
PTE 3076r BB with blown bearings, pretty sure the shaft is bent, housings don't look wrecked.
Have 3 oil pump plates, 1 was brand new before the carnage, 1 came from a running engine (not mine).
Various timing system parts, have at least 2 good tensioners, idler pullies, tensioner pullies,
Got a new water pump, and a used one, neither leaked.
1 end cover with a newer seal in it.
Stock intake manifold.
NGK Plug wires
Non-EEPROM ecu
All the spark plug options you could ever want. BPR8es, br8es, br7es, bpr7es, br8eix
Almost new manual AWD starter plate
Got various pullies and timing covers I just want gone.
Text/call me at 651-245-2218.
-When in doubt, Moar RPM.
Last edited by CarPsyco84; 09-13-2018 at 07:40 PM.. Reason: additions and price drops
Old 07-18-2018   #2
CarPsyco84
CarPsyco84's Avatar
Re: FS: 1g 600ish whp awd part out
Handful of pics. Feel free to ask about something pictured that isn't listed. It all needs to go.
ID:	17151   Click image for larger version
ID:	17152   Click image for larger version
ID:	17155   Click image for larger version
Old 07-18-2018   #3
CarPsyco84
CarPsyco84's Avatar
More of the shell.
Old 07-18-2018   #4
93gtpeater
Drives: cbr 1000rr repsol
Wow you gave up quick on this. I got a vette if your interested. ....
Old 07-22-2018   #5
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Text'd.
Old 07-23-2018   #6
CarPsyco84
CarPsyco84's Avatar
Updated with parts that are sold. Still have a few goodies left.
Old 07-24-2018   #7
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Been waiting for a response but looks like a few of the things I was interested in are sold. Cool cool.
Old 07-24-2018   #8
CarPsyco84
CarPsyco84's Avatar
I wrote back... What are you looking for? I haven't gotten a chance to just start pulling parts yet. People buy the stuff, or at least express interest in it I'll pull it, or wanna come take a look be my guest.
Old 07-25-2018   #9
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Was interested in the ETS FMIC, FP intake, Enkies, JICs and DSMLink but I think I'm good. No response recieved on my end. Oh well. GLWS
Old 07-25-2018   #10
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Old 07-25-2018   #11
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Originally Posted by Alpha D View Post
People get salty so quick lol Bump for quality parts!
Hey, some people value their time. Either way I'm not the one out $3,300! Hahaha God bless!
Old 07-29-2018   #12
CarPsyco84
CarPsyco84's Avatar
Bump for more pictures and a few things I forgot
ID:	17179   Click image for larger version
ID:	17181   Click image for larger version
Old 09-13-2018   #13
CarPsyco84
CarPsyco84's Avatar
Bump for a updated list. Still have a few things around.
Old 09-16-2018   #14
CarPsyco84
CarPsyco84's Avatar
Remaining pile of goodies.
ID:	17237   Click image for larger version
ID:	17238   Click image for larger version
Name:	20180916_170409 - Copy.jpg
ID:	17240   Click image for larger version
ID:	17241   Click image for larger version
Tags
1ga, awd, fp black, part out
