Old 07-03-2004   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Alright,
So I am going to explain things in a four day breakdown:
Day 1: I remote start my car before work from in my house. 5-7 minutes later I get near it and hear a familiar rattling from the tranny. I get in and push the clutch down and it goes away. I take my foot off the clutch pedal and it doesn't come back. Yay.
Day 2: Same thing as day one, but instead of just making a sound, the car shakes a little too. But it goes away once I press the clutch pedal down and let it off. But the worse thing is that when I shut my car off, go inside and come back, it does it all over again. Rattling sound, shaking and then goes away when the clutch is disengaged and re-engaged. Drove it as little as possible.
Day 3: Car really starts to shake alot while making that sound. Also when I disengage and re-engage the clutch(this is all done in neutral) it doesn't shake but makes the sound.
Day 4: This is today. Car shakes and rattles all the time it is in neutral with the clutch engaged. On the way to work it has no problems while in gear and moving. Did notice it was a little harder than usual to downshift while coasting(the anal bastard in me always downshifts through the gears in stead of straight from fifth to first). On the way home from work it was still the same until I had to exit from 494 onto 52, I had to nearly force it into fourth from fifth with the clutch disengaged but it popped right into third from fourth seconds later. Did notice that it was shaking for the first few seconds while upshifting and after gear was selected and engaged. Then when I got to my street and at a stop sign it practically told me "no" to going from third to second, but went perfectly into first from third. But when I left the intersection it shook like a mother until I shifted into second. But slid right back into first without any vibration afterwards while I pulled into my garage where it now sits.
So it has gradually gotten worse but it was willing to cooperate sometimes and not other times.
I recently installed a ACT 2600 and XACT flywheel with a new OEM throwout bearing about 1500 miles ago. The tranny has had a new input shaft bearing installed also. Another thing of interest is that about a month ago I had the fluids changed to a redline mix while replacing a broken output shaft, and since down shifting into first at been difficult while moving.
Monday I will be looking at it myself, and any and every piece of advice will be greatly appreciated as I want to make it to Mayhem. If needed I would even been interested in accepting paid help on Wednesday for assistance with this.
Help a brother out.
Thanks in advance.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
