Old 07-20-2004   #1
chengsta
chengsta's Avatar
the problem i'm having is that the oil going through the turbo isn't exitting fast enough down to the oil feed line(bottom of turbo) causing it to fill up and leak on the oil line(top of turbo)...
ps sorry if this is hard to understand kinda still pissed off cause that is the only thing holding it back from being able to drive again...
1993 Mitsubishi Mirage ES - soon to be EVOIII...
Old 07-20-2004   #2
Enes
Enes's Avatar
is the top bolt tight enough on there? if it is it shouldn't be leaking..
also make sure your drain line is not pluged up somehow?
-E
Old 07-20-2004   #3
chengsta
chengsta's Avatar
yeah the top bolt is tight on and oil feed line is still in good shape... the problem is where the top bolt is, inside of it is a little hole where the oil drains through right well that is the problem.. it just drains very slow and i can't figure out why, i tried spraying the hole, air blowing it and still no luck
