Old 07-20-2004   #1
1991-talon-fan
I have seen products that say they can restore psi in the cylinders and I was wondering if anyone had used them and wanted to know if they are a joke. Thanks
Old 07-20-2004   #2
1Fst14B
if they worked, the engine rebuilders would be out of a job
Old 07-20-2004   #3
There is no "patch" for a worn or damaged engine.
Old 07-20-2004   #4
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
I've used it in a couple off my beaters.
It does help temperarely fill small scores in the cylinder walls and helps old valve seals. Unfortunatly it won't unbend your valves
Old 07-21-2004   #5
HondaKiller
HondaKiller's Avatar
Engine restore cures lifter tick until it's time for your next oil change. worth the few bucks every 3000 mi to cover up a design flaw I can't afford to fix, imo.
HondaKiller is offline   Reply With Quote
Old 07-21-2004   #6
Raptor
ConArtist
Raptor's Avatar
So does sawdust, but I wouldn't use that either. If you do feel the need to try additives, Lucas is about the only company I would trust for any of it. Definately isn't going to provide any cure in the correct use of the word.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
