Old 07-21-2004   #1
1991-talon-fan
Just wondering because I wanted to put in Eagle rods and Ross pistons. The Eagle Rods only go on 6-bolt engines and I wanted to know if I had one. Thanks.
Old 07-21-2004   #2
Enes
Enes's Avatar
you most likely have a 7bolt engine.
if you are going to be building an engine go with 6bolt, its strongly recomended.
But then again it really depends on what your goals are!
-E
Old 07-21-2004   #3
You can buy Eagle rods for 7-bolt engines.
Old 07-21-2004   #4
1991-talon-fan
Where are good places to shop for new engines. Mainly 6-bolts?
Old 07-21-2004   #5
Originally posted by 1991-talon-fan@Jul 21 2004, 12:41 PM
Where are good places to shop for*new* engines. Mainly 6-bolts?
Your local Mitsu dealer.
Old 07-21-2004   #6
Buy a used 6 bolt and throw in eagle rods and weisco pistons. If you don't have money for pistons and rods, go with the stock 6 bolt rods and weisco pistons. You have a 7 bolt if it is a 93.
Old 07-22-2004   #7
93laserawd
I have a 1993 laser rs awd turbo 5-speed and I think I have a six bolt motor.
Old 07-22-2004   #8
Enes
Enes's Avatar
I might already be a winner of the sweepstakes, i just have to buy some magazines too
-E
Old 07-22-2004   #9
Check vfaq and you will be able to tell for sure. All you have to do is feel or look under the car at the oil pan. You would only have a 6 bolt engine if someone did a 6 bolt swap for some reason.
89-92.5 = 6 bolt
92.5-99 = 7 bolt
