Old 08-09-2004   #1
Khadgar
Can't Actually Wrench
Ok so I got done putting my car back together after isntalling a 255, 550 injectors, dsmlink, and a few other little things.
First what I did was I went in to dsmlink and started the pump, i didnt smell any leaks in the engine bay and I can hear the fuel moving around.
When I try to start the car it cranks, but it doesnt sound as healthy as it usualy does, and well, it doesn't start.
I checked and I have all the connections that you can see from the top of the engine, plugged in.
Maybe my ignition coil thing behind the engine bay isnt plugged in? But I am almost 100% sure it is.
Well I'm going to go pull a plug and seee if there is spark if I can't figure anything else out.
Old 08-09-2004   #2
Khadgar
Ok my injectors ARE leaking. How do I fix this? And I still don't know why it wont start...
Old 08-09-2004   #3
Enes
Enes's Avatar
DSMLINk, swap the wires 14 and 23
-E
Old 08-09-2004   #4
make sure to swap in new o-rings and insulators on the injectors.
Ask Cher why you don't want to drive with leaking injectors...
Old 08-09-2004   #5
Get new injector o-rings and insulators. Did you pull the head? Is the HG on the right way? Check for fuel and spark. Is the CAS 180 out?
Old 08-09-2004   #6
Enes
Enes's Avatar
boom booom boom shakalaka .. boom..
-E
Old 08-09-2004   #7
Khadgar
DSMlink CAS invert on, only ONE injector is leaking, I reused the orings cause they were only a few months old but put on new insulators, its the insulators that are leaking... ok for some my greddy boost gauge is seeing a spike in boost when the car is just cranking?!?
maybe its cause its an electrical gauge...
Old 08-09-2004   #8
Khadgar
I also swapped 1 for 2 and 3 for 4, when i crank it, it just makes loud backfiring noises.
Old 08-09-2004   #9
Enes
Enes's Avatar
when you look at the coils.. they are 2 seperate coils.. first coil is for 1 and 4 , second coil is for 2 and 3 just swap them around and you will be fine...
-E
Old 08-09-2004   #10
Khadgar
rgr
Old 08-09-2004   #11
Raptor
ConArtist
Raptor's Avatar
Since the car is a 95, unless you used a different CAS, you should not have to use the CAS inversion feature. You definately should have the #1 plug wire swapped with #2 and #3 swapped with #4.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 08-09-2004   #12
Khadgar
I'll turn off cas invert, but why does the boost gauge spike when it backfires
Old 08-09-2004   #13
Khadgar
CAS invert off, plug wires swapped, just backfires and dies.
Old 08-09-2004   #14
Khadgar
CAS invert off, plug wires NOT swapped, it starts.
Ok it stopped running, and wont start that way again.
Old 08-09-2004   #15
Atleast it now runs,
Old 08-09-2004   #16
Enes
Enes's Avatar
yup
Old 08-09-2004   #17
Khadgar
It wont run anymore =/
Old 08-09-2004   #18
Khadgar
ok mb my injector clip wires are backwards? can anyone check and see what side the green wire is on(the wire that is the same on each injector) and if it is on the same side on all of them
Old 08-09-2004   #19
You have the global slider set for the 550s?
Old 08-09-2004   #20
Khadgar
Global slider set?
