Old 08-16-2004   #1
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Please help me out!
I'm pretty sure DSMs have a couple free mods that I can do, but I'm not getting them as of the moment. Someone please specify and let me know what they are. Thanx,
-Lor
Old 08-16-2004   #2
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
For 1G's there are 2 things that you can do.
1. Remove the silencer behind the MAS sensor
2. Remove the BCS restrictor (best done if you have a boost gauge)
I guess you can also hack your airbox if you want
tsiawdspeed is offline   Reply With Quote
Old 08-16-2004   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Pics are broken, but they have a fair number of cheap tweaks. DSS
Old 08-17-2004   #4
IndiEP
Tha MIG Masta!
IndiEP's Avatar
Someone correct me if I'm wrong! But I have the vacuum source for my bcs coming from the bov not the air canister/outlet elbow. The car has not been started like this yet but I have it hooked up like a boost controller. Now it sees pressure post IC w/out the pressure drop from the IC. I'm not an expert on the workings of the bcs or how its designed nor have I tried it yet so I have no idea if I'm just rambaling or if this will get you an extra pound of boost.
Austin
Old 08-17-2004   #5
tsiawdspeed
I dont think that way will work but I also don't really know how the stock BCS works. Here is my theory and please correct me if I am wrong. Under low boost, the BCS is open so the wastegate is not seeing any boost, and therefore stays closed. When you hit enough boost, the BCS closes and the wastegate sees that boost and the wastegate opens up. So, I think, the way you have it set up, the wastegate will be seeing boost until it hits the stock boost setting and then it will boost more because the BCS will close, which cuts off the boost from the wastegate so it can't open.
Old 08-17-2004   #6
turboimports
thanx all.
-Lor
