Old 08-24-2004   #1
nightstalker
Can anybody give me any possible solution to y i'm running rich, heres the mods i have done, stage 2 extreme 16g ported turbo, ported manifold, extreme fuel pump, extreme intake, UICP with 1st gen BOV, Clutch Masters hdsb clutch, 3" thermal R&D Exaust system, HKS EVC IV Electronic boost controller, HKS Type 1 turbo timer, and B&M Short shifter kit. And another problem i have is when i start my car up in the morning i have to hold the ignition in the spot so it actually catches b/c of i don't it will shut off. I don't think its my starter, but any help would be awesome.
Old 08-24-2004   #2
Nash
Nash's Avatar
Why do you think the car is running rich?
Old 08-24-2004   #3
nightstalker
B/c my friends tell me when i'm driving in front of them that they can tell when a huge cloud of smoke comes from my exaust.
Old 08-24-2004   #4
What color smoke? Black, blue, white, pink? How much boost are you running on that 16G with the tiny stock 2G intercooler?
Old 08-24-2004   #5
Blue = oil
while = coolant
black = rich or lean
pink = huge turbo swallowed something
Old 08-24-2004   #6
nightstalker
Its black
Old 08-24-2004   #7
nightstalker
and i'm pushing 14.5 psi
Old 08-24-2004   #8
Could be either.
Lean : burning the carbon off your pistons
Rich : unburnt gas making its way out the exhaust
Old 08-24-2004   #9
nightstalker
So got any help with a fix or just trake it to mitsubishi and get it tunned up?
Old 08-24-2004   #10
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Get an EGT gauge and a datalogger. Examine the data and you will be able to tell if its rich or not. Will most likely end up costing you the same price as a trip to Satan.
Old 08-24-2004   #11
You can borrow a dattalogger or buy one, get a EGT gauge or a wideband, of drop the boost and see if it changes. If you drop the boost and it goes away, it was running lean. You could also check your spark plugs.
Old 08-25-2004   #12
nightstalker
oh ok thanks guys
Old 08-26-2004   #13
fmicmatt
I'll be in Harrisburg, PA in a week.
I've got a Universal WB Sensor/Datalogging Software to check it out.
Maybe an AFC should be your next mod.
Note: Most 2Gs I've seen without cats smoke(rich/safe) under hard boost.
-Matt
Old 08-27-2004   #14
EGT is worthless. Its a FWD take it do a dyno with a wideband o2, or buy a wideband and put it in your car.
