Old 09-04-2004   #1
SquackDiddy
Send a message via AIM to SquackDiddy Send a message via MSN to SquackDiddy
or float? something bout the valvetrain
I am on suspension because I refuse to type a decent sentence.
SquackDiddy is offline   Reply With Quote
Old 09-05-2004   #2
Definition: A high-rpm engine condition in which the valve lifters lose contact with the cam lobes because the valve springs are not strong enough to overcome the momentum of the various valve train components. The onset of valve float prevents higher-rpm operation. Extended periods of valve float will damage the valve train.
Old 09-05-2004   #3
SquackDiddy
thank you
Old 09-05-2004   #4
Raptor
ConArtist
Raptor's Avatar
It should also be known that excessive seat pressure can cause damage as well as waste power. You only need springs that are strong enough to keep the valve closed appropriately within the RPM range the motor will see.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
