Old 09-07-2004   #1
Enes
Enes's Avatar
whats the best way to disable the starting of your car thru one switch..
This would be as a deterent for theft where in order to start a car you have to flick a switch or two
I am thinking of doing the one switch for the coil plug, and or something else...
and just hide it somewhere inside the car..
but what else or what would be safest..
-E
Old 09-07-2004   #2
You could do starter disable or maybe a battery switch, which will cut your battery off from everything.. but then you lose memory from the radio or what not.
Old 09-07-2004   #3
Enes
Enes's Avatar
what radio.. i have no radio
and ecu gets re-populated from laptop
-e
Old 09-07-2004   #4
santa
Boost Spike
santa's Avatar
I'd do the clutch cut wire right by all the fuse's right by the clutch pedal assembly personally.
Old 09-07-2004   #5
Enes
Enes's Avatar
i have that one unpluged anyways.. hmm..i could do like 2 switches or something one for the fuel pump.. one for starter, and maybe the 3rd for the clutch wire.
with the clutch one, it wouldn't even crank over right?
-E
Old 09-07-2004   #6
Why not just do a battery kill switch? That way EVERYTHING is dead.
Old 09-07-2004   #7
ThorCW
I have my honda set up with push button start and what i did is wire a small switch kinda like the old bright lights switches on the floor and i hid it under the carpet in a spot no one put their foot but me and i hit that with my foot then that engages the button
