Old 09-27-2004   #1
If I was to have someone else remove my balance shaft from a '92 4G63 6 bolt block, could I just bring them the front cover with the balance shaft attatched? Or would they need the whole block too?
Old 09-27-2004   #2
Front balance shaft is attached to a gear and runs on a balance shaft belt, rear shaft is part of the oil pump housing, driven off the timing belt.
Neither are attached to the block directly.
WWW.VFAQ.COM :goodluck:
Old 09-27-2004   #3
CDeutsch
CDeutsch's Avatar
They would need the block too if they were going to spin or replace the bearings to block the oil holes, unless you are going to do that yourself.
http://www.vfaq.com/mods/balance-shafts.html
06 Evo IX RS
99 Miata
Old 09-27-2004   #4
Raptor
ConArtist
Raptor's Avatar
We drill tap and plug the bearing oiling holes in the block so we would want the block as well. I doubt anyone else would. Most places just spin the bearings.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 09-27-2004   #5
CDeutsch
CDeutsch's Avatar
Jesus, won't you guys do anything half-assed? :stick:
j/k
06 Evo IX RS
99 Miata
