Old 09-28-2004   #1
IndiEP
Tha MIG Masta!
IndiEP's Avatar
I need to fix my clutch master cylinder. Its either 95.00 new from dealer/napa but the dealer also carries a rebuild kit for 30, I was told no one realy buys it. Just wondering if theres a reason to stay away from the kit or any other info would be appreciated, cause thats a big difference in $$.
Austin
Old 09-28-2004   #2
The rebuild kit just replaces the seals and piston, if the cylinder is damaged it will still leak. Autozone has the best prices, I believe the clutch-master is ~$56 and a slave is ~$17. These are brand new, not rebuild/reman.
Old 09-28-2004   #3
If you want used, I will give you both and the line for $30 off my 90 laser. The car shifted perfectly. It is a 90 FWD if it matters.
Old 09-28-2004   #4
IndiEP
Tha MIG Masta!
IndiEP's Avatar
Thats a good point, I'd assume its the seals but you never know. I'll give atuozone a call. thanks
Austin
Old 09-28-2004   #5
Id buy a new one.
