Old 10-02-2004   #1
Wizard50369
Send a message via AIM to Wizard50369 Send a message via MSN to Wizard50369 Send a message via Yahoo to Wizard50369
One day i get bored and decide to rebuild my trannsmission cause.... well i just felt like it. Ive never had experiece with them but what the hell, i need to learn some how. So i get the tranny out, everything goes good..... new gears, seals, the works. All back together, shift into first and it goes good. Shift into reverse... and nothing. :headache: I ended up with one washer but everything else went back in. Any help as to why it wont go into reverse but into all other gears?
Ignorance Is Not A Virtue
Wizard50369 is offline   Reply With Quote
Old 10-02-2004   #2
Enes
Enes's Avatar
LOL yeah, same issue here once..
there were two little balls that fit inside the rails/forks make sure they are still there..
but i'd wait on that untill somone else here with more trany experience pops in and says something about it
Old 10-02-2004   #3
Wizard50369
Thanx for your help, im pretty sure that they are they because they fell out once and i put them back in.
Old 10-02-2004   #4
Wizard50369
Looking at some pics i think i mixed the 2 syncros (those are the brass looking things right? lol) on backwards. The ones when you first take the case off.... by the reverse. I see that there is one syncro with teeth that go all the way around, and one that has 3 cut outs. So... would switching the 2 have anything to do with it not going in 5th? or does it not matter?
Old 10-03-2004   #5
The one with 3 sets of teeth goes on the outside and a wave spring holds it away from the end case. You need to have the passenger side of the car jacked up to get it to stay on while you're putting on the end case.
Old 10-04-2004   #6
Wizard50369
its not the syncros because i had them on right the first time :headache: . This sux, but at least all 5 forward gears go in with ease :bounce: . I have to take it all apart and check the reverse gear and shaft to see if i put them in right. what a headache this is. Ill let you guyz know how it turnz out.
Old 10-04-2004   #7
Practice makes perfect.
Old 10-05-2004   #8
JustROLLIN
SpunBearing
JustROLLIN's Avatar
If it shifts into reverse and doesnt actually back up, its possible that you messed up the idler gear install. Just a thought.
Old 10-06-2004   #9
Wizard50369
Thats what i was thinking so i took it back out again today and put it back together (seemed to work up until i put it back in the car!) What is the "right" way to put the idler gear in? does it have to go in after the other gears or does it not matter? Third time ive done this :bs:
Old 10-16-2004   #10
Wizard50369
Ok so i take out the tranny again. check over my work and notice things that i had done "wrong". I put it back together, making sure with each step that the gears rotated and shifted. I checked all the way until i put the final cover on the tranny, but didnt check after that. So i put it all back in the car, start it, let go of the clutch and it lurches forward and dies. In Neutral!! Now i have what i think is second gear as Neutral and no other gears. :headache: :headache: :headache: This is so much fun!
Old 10-23-2004   #11
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
ever get that fixed? lol
- Josh L.P.
Old 10-24-2004   #12
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
how hard was it to do the rebuild? 1-10, tem as really hard. Is there some where you read how to do it?
7/25/09
Old 11-04-2004   #13
Wizard50369
Never did get it fixed, supposed to take it in tomorrow hopefully . On a scale from 1-10 i would like to say it was 5 but since i couldnt get it fixed i cant really say that. lol. Its easy if you remember where the pieces go. Take lots of pics and you should be fine. I didnt read about it till after i got it apart, than i noticed there is a section on the VFAQs.
Old 11-04-2004   #14
Wizard50369
Anyone want to sell me a transmission? LOL. The shops want $350 for "bench work". whatever that means. but i saw someone selling one for $250.
Old 11-16-2004   #15
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Anyone have an extra one after they sell it to Wizard first? I'm thinking about rebuilding mines, but I dont have the slightest clue on how and plus I dont have tools worth anything at my house...can barely find jack and cant find a wrench...hahaha
