Old 10-12-2004   #1
DSMkel
Send a message via AIM to DSMkel Send a message via MSN to DSMkel
Do I need anything special to install my 1G Cyclone intake manifold on my 95 TSi FWD???
Type-Arrrrgh KILLA
"If it's never broke you're not driving it hard enough"
DSMkel is offline   Reply With Quote
Old 10-13-2004   #2
1g intake mani gasket....
Old 10-13-2004   #3
DSMkel
Anything else?
Type-Arrrrgh KILLA
Old 10-13-2004   #4
A 1G head so that the airflow doesn't hit a big wall might help. It might be hard to fit in there also, if you have A/C.
Old 10-14-2004   #5
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Try to sell the thing for more than you paid for it and just get a 1g intake.
Old 10-14-2004   #6
DSMkel
Why would I sell it and get a normal manifold? Wouldn't that be kinda stupid? :blink:
Type-Arrrrgh KILLA
Old 10-14-2004   #7
No, the normal 1g intake manifolds are better. The cyclone ones don't flow more and they are a pain to deal with.
Old 10-14-2004   #8
Khadgar
Can't Actually Wrench
From what I've heard compared to the 1g it flows less on the high end but low end better/faster spool. Not sure how accurate that is, I've heard something of a canister used when hooking them up? seems to be a good reference.DSMTuners
Old 10-20-2004   #9
npaulseth
Search is your friend. Sell the manifold BTW.
Old 10-20-2004   #10
Thread has been cleaned up. Stay on topic or it will be closed.
Just answer his/her question or give him/her advise on the best thing to do.
STOP THE NEWBIE FLAMING CRAP!
Old 10-28-2004   #11
TurboMeTroy
Send a message via MSN to TurboMeTroy
From my experience, I saw absolutely no gains from the Cyclone intake on a 93 Talon....if anything, it's a downgrade in my opinion.
TurboMeTroy is offline   Reply With Quote
Old 10-29-2004   #12
It is a proven downgrade for top-end power.
Old 10-29-2004   #13
LightningGSX
Hellbound
Since he asked what he needs to install it and not how it compares to others....
The cyclone is designed to give better LOW end, while keeping a decent top end.It has a valve that switches between either high velocity runners or high flow runners.For it to work properly you need some electronics to actuate the valve at the correct RPM.I'd recommend just buying a RPM adjustable nitrous switch, and using that to actuate the solenoid.
-Nulli Secundus-
Old 10-29-2004   #14
There is one spot out there that hadf a before and after dyno of going to a "cyclone" manifold from a 1G intake manifold and there was 1 more torque out of the cyclone. definatly not worth the swap. Get a 1G intake manifold or save money till you can get a sheet metal intake manifold.
