Old 10-17-2004   #1
Do you have to remove the valve seals, cams, rockers, etc? What type of solvent should I use? Is there a safe and easy way to get the detonation marks off the valves?
Old 10-17-2004   #2
Emcee gsxtc
Emcee gsxtc's Avatar
Honestly take it to a machine shop, or somebody with an amazing parts washer. When my head came back from the shop it was clean and realy purdy.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 10-17-2004   #3
b00stingsx
Send a message via AIM to b00stingsx
i took all the guts out of mine, and washed it with brake cleaner and a degreaser. it turned out looking like new.
b00stingsx is offline   Reply With Quote
Old 10-17-2004   #4
I took mine completey apart and just used various brushes and Simple Green and brake cleaner.
Old 10-17-2004   #5
Yea you can either just clean it like Matt did or take it in to get it hot tanked. Thats what I did when i had mine rebuilt, it was shiny afterward.
Old 10-17-2004   #6
Raptor
ConArtist
Raptor's Avatar
If you are taking it apart to clean it, take the plugs out of the end of the oil galleys so you can make sure all the junk that gets in there is gone. If you don't have a compressor, you shouldn't do it, you need to be able to blow it all out when you are finished.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 10-17-2004   #7
Ok, thanks.
