Old 10-17-2004   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
I was shifting tonight and when i tried to shift into 2nd it was like there was nothing there? like i could move the shifter all over and it wouldnt go into any gear. So i checked and i found out what it was. Its hard to explain, like if you follow the shifter all the way down into the consule, its at the bottom and its connected to a little O shaped eye thing. well its that cable that connects to the end of the shifter. Every time i shift i have to like retighten it, like it somehow becomes loose. Is there a way to fix this for good?
Old 10-17-2004   #2
Most likely the entire shifter cable assembly will have to be replaced. Twice Cher has broken his linkage as of late and it affects what you said.
Old 10-18-2004   #3
Enes
Enes's Avatar
i have a set of good cables for a 91 if thast what you need
Old 10-18-2004   #4
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Tighten it with two 10 mm wrenches.
'04 Honda Ricer: stock
