Old 10-25-2004   #1
b00stingsx
Send a message via AIM to b00stingsx
everything is plugged in, fuses are good. any ideas?!
b00stingsx is offline   Reply With Quote
Old 10-25-2004   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Did you check the fan relay?
Old 10-25-2004   #3
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Do the fans turn on with the A/C on? Are you overheating?
Take her to the limit!
Old 10-25-2004   #4
Iceman
He told me the fan for the A/C doesn't turn on either.
Old 10-25-2004   #5
check the ralays in the passengers side of the engine bay. Mine went out a while ago. The dealer wants $25 a piece but John's gave them to me for free with a purchase. Is the car overheating? The fans are not always on...
Old 10-26-2004   #6
Thermo sensors okay? Everything plugged into the radiator/t-stat housing?
How about the wiring? fuses?
Old 10-26-2004   #7
Emcee gsxtc
Emcee gsxtc's Avatar
1 good option is to just hardwire them to a switch, I have done it in a couple cars. It is especially handy at the track.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 10-26-2004   #8
LightningGSX
Hellbound
You can pull the plastic cover off the relay, and manually actuate it with your finger.This will quickly narrow down the problem.If nothing happens when you actuate it, the circuit after the relay has a problem.If the fan turns on, then its most likely the circuit before the relay or the relay itself.You can test the relay with an ohmeter across the relay's coil contacts, if its open or has a high resistance, then the relay is bad.
-Nulli Secundus-
Old 10-26-2004   #9
b00stingsx
Ok, the fan in front of the turbo turns on when the ac is running. I have replaced the relay once and that didnt do anything. I am just about ready to run the fans off a switch.
Old 11-07-2004   #10
b00stingsx
The left side fan is tottaly shit. I hardwired some power to it, and nothing. RIght now I am just running the one fan, and that is hardwired to a switch. I am going to pick up another used fan and hardwire that one in too for extra cooling.
Old 11-07-2004   #11
If ya feel like digging around, I have a fan for ya. Not sure where though.
