Old 10-31-2004   #1
JasonR
FMIC Differences
Do you guys think Bar & Plate style fmic are better or Tube & Fin? Which manufacturing technique offers better heat exchanging properties? Many factors go into this comparison so lets compare the 2g Greddy tube & fin big fmic to 2g Slowboy bar & plate big fmic. Also keep in mind that the i/c piping design is different. Slowboy has a shorter distance from turbo/fmic/bov/throttle then Greddy because Greddy utilizes the area where stock intercooler used to be, then upper i/c piping goes to throttle. Which one do you believe is better even though both are very good fmic's.
Old 10-31-2004   #2
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
go to your control panel and activate your PMing. I am trying to pm you but it wont let me cuz you havent done it yet!! call my phone if you got a question about it.
- Josh L.P.
Old 10-31-2004   #3
Greddy offers 2 core choices in their DSM applications. 1 is a V Spec and is your "tube" design, and one is the R Spec and is you "fin" design. The design is both of them is set for differant applications. The V setup is used more for factory sized turbos with a little more boost and the R setup is used more for those big dick slinging turbos. They are both basically tube and fin design cores, just have a little differant design and thus used in differant applications by those who do buy specific for their application.
A good bad and plate design is generally able to hold more pressure and is generally built for maximum performance with less pressure drop and usually has more "uniform" dimensions. Generally the way to go if it's a well built core in my opinion.
And tonight I can't sleep or spell at all.
Old 10-31-2004   #4
Both of the GReddy FMIC's for our cars are the R-spec cores.
Old 10-31-2004   #5
Pimpin Dsmstyle
Br0k3N
Hes running a greddy right now... it kinda has a long piping route back home. So he is wondering if there is any way to get more power out of a slightly ( or highly) different intercooler setup. Looking for over 500 whp, so whatever would work best for that...
- Josh L.P.
Old 10-31-2004   #6
The Greddy kits are ok. They are fairly inexpensive compared to the better kits out there. People have made decent power with the Greddy's, but you would have a hard time finding a kit that didn't perform better, unless you made one out of some of the cheap cores sold on EBay. If you really want to make power especially on pump gas, then get something better then the Greddy.
Old 10-31-2004   #7
Aside from the core not being all that good with the Greddy, I have never liked the way that the piping goes out through the passenger fender. Or can you get kits that don't do that, all the ones I have saw it seems like the UICP would be kinda restrictive.
CRAIG
Old 10-31-2004   #8
admin
Administrator
Since Greddy was one of the first to put a kit into production for the 2Gs they tried to make it as easy to install as they could and obviously it sold. But now with all the custom short route kits and one off designs the Greddy and APEXi kits are not the greatest choices anymore unless you score a sweet deal on the core and have custom piping I'd skip them.
admin is offline   Reply With Quote
Old 10-31-2004   #9
Pimpin Dsmstyle
Br0k3N
he always is running c16 if that matters. Hes looking to break 500 whp next year and is getting a bigger turbo and was told to do something else with his IC and piping. Hes mainly concerned with the 2 different TYPES of ICs, and the way its routed. How much does the piping hurt / benefit for performance? Sizes.. routes.. length.. material.. etc.
- Josh L.P.
Old 10-31-2004   #10
Well 2.5" piping is widely the most popular diameter piping that is used. And obviously you want the least amount of bends and the shortest route possible. The least amount of "walls" that air can hang up on the better with turbo applications especially.
The smaller the piping the more restricted its going to be as well. Some people go with smaller piping (like 2") to make more torque. For a daily driven pump gas car this wouldn't be a bad idea, however you are not going to be able to make big HP numbers as you would with bigger size piping.
In your friends case, if he is trying to make 500hp and is running C16 with 30+lbs of boost, he should use the shortest route piping and use the atleast 2.5" diameter. Also if he is using a aftermarket intake manifold, a bigger throttle body would not be a bad idea as well.
The basic idea is to let the air go from the turbo through the intercooler up to the intake manifold and into the motor as easily and efficiently as possible. There are numerous variations to achieve this, you just have to pick one that is functional and cost effective.
CRAIG
Old 10-31-2004   #11
Here are some of my thoughts...
It really depends upon what you consider better. Are you looking for a better cooling charge? less pressure drop? better air penetration (less c/d)?
Tube and Fin cores allow air to pass through them easier. This allows for a cooler charge to make it to the radiator (in a fmic application) which will help aid in the prevention of overheating. The reason they do so, is due to design. Where-in a bar and plate (and a plate-tube and fin core) are more squarish, the tube and fin core almost 'points' outwards, thus piercing the air easier.
A tube and fin core makes a 'V' while the bar and plate make an '[]' shape and the plate-tube and fin makes a 'W' shape. Therefore they rank in order.
1) tube and fin
2) plate-tube and fin
3) bar and plate.
This is in the c/d category as well as cooling running engine factor. Granted how the nose of the car is shaped will change the efficiency and mounting method of the intercooler and radiator greatly. The more direct of a path airflow has to the intercooler, the greater the efficiency. To thick of a core can sometimes 'trap' air from getting through it, as well as to drastic of a mounting angle. These problems can be overcome by allowing for more surface area in a trade off of thickness.
Next section...how the air moves through the intercooler.
The faster the air can get through the intercooler core the better. This pretty much sums up 'pressure drop'. When the air has a hard time dividing up through the runners, pressure drop goes up 10 fold. Plate-tube and fin cores are the best in this situation. They allow the air only once choice, that is to split and enter the core. This is usually based on the manfacture, but mostly the plate-tube and fine cores result in the least amount of pressure drop. Second in this category is the bar and plate. They sometimes make the air do a 90 degee split then enter the tubes, but it usually works out. Lastly the tube and fins are the worst. Air usually has to do a 180 when it doesn't grab a tube right away, bounce back against the endtank, and go back at the tube again. Not the greatest idea when it domes to pressure drop. Manafacture methods can sway these results on way of the other, but this is in general.
So.. when it comes to pressure drop.. Plate-tube and fin #1, followed by bar and plate, then tube and fin in a distant third.
Next we actually talk about cooling.
Bar and plate are by far the best at cooling an air charge. They displace more heat then the other two examples widly available. A few changes within the manafacture method will change the outcome, but overall bar and plate is better at getting rid of heat. A properly made tube and fin core can beat out a plate-tube and fin core as well as a bar and plate, but overall most manafactures don't construct them correctly and when they are, the usually cost quite a bit.
Actually I am getting tired of posting so i'll sum it up.
There is no better one. It really comes down to a multitude of options. Bar and plate cores are good overall if constructed properly. Granted they are the most prone to leaks, if the endtanks aren't attached correctly, but overall they are better. Plate-tube and fins are also awesome cores. Tube and fins can be the best, but usually aren't due to the expense of making them correctly.
I didn't even get into the other very very important aspects of intercooling, like endtank design, fin design and shape (louved vs straight...spacing, amount of fins etc)..piping sizes, coupler use..bend radius's..etc.
Most of the time the only hamper on awesome intercooling is money. That is of course if you don't go insane and use to large of an intercooler.
That being said, a few manafactures out there stand out. Also try to find out of the 'pressure drop' advertised is static or dynamic. Static is best defined as 'flow bench aquired' pressure drop numbers where dynamic actually is closer to real life and takes into effect the entire design of the intercooler, from basis (tube and fin vs bar and plate), to fins..etc..
That being said, here are a few manafactures and what I think of them..
Spearco intecoolers.
They are widely available and are actually good stuff. They have realitivly low pressure drop numbers, have a wide range of cores available and in general are a great option.
Btw they are a high efficent pierce fine design on the inside and out. This results in awesome efficiency in the air charge department as well as low pressure drop.
PTE use a bar and plate style core. they are widely available, very economic, and when paired with good endtanks can flow very well. There core choices aren't as vast as spearco, but they do hold there own.
Those are a few of the companies I have done research into, google does wonders, so does being on ALOT of boards.
other companies worth mentioning:
ARE cooling- aluminum radiator and engineering. Australia based company. From what I have gathered, have awesome intercooling making functions but aren't the most economical choise. They can pretty much custom make any core you need, and are a good choice for the 'budgetless' project.
ARE cooling
The greddy cores are also widely used, and I"ll let others chime in on those, as I have very limited research into them as well as experience.
Also this information only applies to air/air applications, air/water is a completly different ball game where you can get over 100% efficiency if you do it right.
Hope it helps, otherwise enjoy the ramble.
Good day to all.
Old 11-05-2004   #12
Pimpin Dsmstyle
Br0k3N
Where is the rest at josh? Im getting sick of reading this one over and over.. I want to learn more!! I think he should give us some more knowledge. what do yall think
- Josh L.P.
