Old 11-19-2003   #1
Mike_91_TSi
Well this time I went out and but the little buzzer like in the vfaq rather than using my multimeter. The code I pulled was 41 - Injector. It seems to me that many things could be wrong with the injectors. Do you all have any idea of were to start with this one. I am still running stock 450s. I have an extra set of 450s. Should I just swap them out?
My car has very little mods.
UICP
Test Pipe
Cat Back
K&N cut air can
No upgraded fuel management and no boost controller.
If someone could piont me in the right direction it would be most appreciated.
Old 11-19-2003   #2
If you got 'em, swap 'em.
At least you'll now if it's the injectors or not.
Old 11-20-2003   #3
Mike_91_TSi
Well...I have swapped them. So far so good. No Check Engine Light. Hopefully it will get me the 28 miles to work tomorrow. :3gears:
Old 11-20-2003   #4
Hopefully that helps. If you ever want to know what is wrong with the others, you can put them back on and feel them. Sometimes a faulty injector will get hotter or vibrate more than the others.
