Old 12-02-2004   #1
JasonR
Gm mas vs. 2g mas
I have 2g mas with 2 out 4 honeycomb sections removed. I know the gm mas flows better. Will the 2g mas be fine up to 500whp. I was under the impression it will not work and need gm mas. I use dsmlink too. I am trying to make my decision based on the best set up and easier to tune with? Any response is appreciated.
Old 12-02-2004   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
I like the GM maf idea.
Take her to the limit!
Old 12-02-2004   #3
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I like mine, it is a much more free flowing MAS. Plus the ability to put it in blow through config is good for over flow and reduces turbulence before the turbo, also as every ricer can appreciate you can vent your BOV with no ill effect.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 12-02-2004   #4
Yea and if you blow an intercooler pipe you dont have to worry about your car stalling and dying and then not having steering haha. (happened to me)
Old 12-02-2004   #5
Nash
Nash's Avatar
I made 426 with a 2G MAS with my old 20G.
Old 12-02-2004   #6
With some modifications you can probably make 500whp or more with the 2G MAS, whether is be more hacking of the unit itself, adding a bypass filter, or ignoring its output past some point. DSMLink has functions built right into it to get around MAF overrun. Blaha ran 10.5 on a 1G MAS, throw one of those on there.
I prefer no MAF/MAS at all.
Old 12-02-2004   #7
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
I’m going GM maf because, I need to have more room for IC piping and like the flexibility of the GM maf. and I still like GM.
Old 12-03-2004   #8
Sean485
I have a gm maft in blow through and I love it. The 2g mas is sufficent for alot of power but it is still a restriction and it is very bulky and karmen vortex maf's are a poor design IMO. If you have the money i'd go for a gm maft.
Old 12-03-2004   #9
I liked my 3" MAF in blow-through....quick spool and quick throttle response.
Old 12-03-2004   #10
JasonR
Thanks for responses. Looks like I wont be cutting any corners. Gm mas with translator is the way to go. I just cant find ways to cut corners with the bigger turbo. I got to replace tranny/fmic/exhaust manifold/external wastegate/i/c piping/intake manifold/bigger injectors/etc. Oh well.
Old 12-03-2004   #11
SpicyOrange
Hey guys I'm gonna pop in here with another stupid question. What Gm MAF sensor are you using?, and are there any articles on the install?
SpicyOrange is offline   Reply With Quote
Old 12-07-2004   #12
LightningGSX
Hellbound
Why do you think Von Karman sensors are a bad design?
-Nulli Secundus-
Old 12-07-2004   #13
Sean485
Thier really restrictive, and if you get too low of airflow through them (hacking the mas too much) the air going through the metered section doesn't have enough speed to make the vorticies consistantly and it gets an incorrect reading and if you get too much airflow through them it also has issues creating and counting the vorticies consistantly (mas overrun)
A hotwire mas or vpc (map sensor) system is much less restrictive and consistant IMO.
Old 12-07-2004   #14
3.5 inch LS1 maf.
Old 12-08-2004   #15
I was using the 3".
Old 12-08-2004   #16
Sean485
I am also using a 3" sensor. If you are running draw through a 3.5" sensor wouldn't hurt if you have a big turbo but 3" sensor would be more suitable for blow through with your average 2.5" ic piping. Running a 3.5" sensor with 2.5" piping is too much of a transition too quickly IMO and wouldn't help very much.
As for the install are you running blow through or draw through? If your doing draw through you just stuff a 3" filter on the inlet of the maf and the maf should fit right into your intake tube just like the stock mas. If your doing blow through you just need to physically find room for it in your ic pipe (which will obviously vary depending on your current mods and remeber to figure in the length of the couplers) and then cut the pipe and use 2 renforced silicon reducers with t-bolt clamps.
Old 12-08-2004   #17
3.5 inch LS1 maf.
In draw through configuration.
