Old 12-08-2004   #1
caustad
No power to fuel pump. Wiring? Help!
I recently replace my tranny and transfer case but had the car garaged for about a year before I did the work. After I finished it would not start and the fuel pump wasn't getting power. I checked all the fuses and even swapped out the ecu to try another just in case... Still no power. I decided to do a fuel pump rewire and the fuel pump turned on, but the injectors just sprayed wide open and wouldn't shut off. It's not the ECU because it does the same thing with both. I also thought that I might have pinched a wire when I put the tranny back in but I didn't see anything. Any ideas?
caustad is offline   Reply With Quote
