Old 12-08-2004   #1
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
TRE syncros. Same as mistu?
I need to know if the syncros TRE sells are any different from Mitsu syncros, or if they simply buy all that from mitsu.
More specifically, if their "double syncro" set is simply a 93+ syncro set from mitsu.
Thanks,
Chris
Old 12-08-2004   #2
520Talon
I had a TRE Tranny with the double syncros. When it went I had Shindly rebuild it with the mitsu pieces. Had both pieces side by side and they looked the sam and worked the same. YMMV.
520Talon is offline   Reply With Quote
Old 12-08-2004   #3
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
OK, so when you rebuilt your TRE double syncro tranny you just went with the 93+ syncros from mitsu, correct?
Old 12-08-2004   #4
TRE doesn't make their own synchros, they're factory Mitsu parts. The second gear set is 95+ if I remember right.
Old 12-08-2004   #5
FORSFED
The syncros are the same as stock, but they sell a 'modified' second gear with their kit. All they do is cut an angle in the teeth of the second gear (right after the synchro) where the hub assembly slides onto to select second gear. So instead of being centerd like the stock gear it's offcentered kind of like this profile.
Sync Teeth
Sync Mod Teeth
Old 12-09-2004   #6
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
So does it make any difference at all? Or would I be just as well off buying 95 + syncros being that I have the TRE double syncro 2nd?
Old 12-09-2004   #7
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
So let me get this right. TRE does some minor machining work and they use STOCK parts? Why would a person want to pay so much for something that is not much better. Or is this machining more intricit than i suspect? Is this something a guy with high mechanical skills could do on his own? I read this because i know 2nd gear syncs are horrible ( at least ive had bad luck) and i might want to replace it sometime. However, why not upgrade if i have to go in there anyways!?
- Josh L.P.
