Old 12-15-2004   #1
santa
Boost Spike
santa's Avatar
1g n/t head?
Is there any difference in a n/t head to a turbo head I have no idea. Also there is a kid thats wondering in my class if the motor's are different at all or what not also? as far as internals go? thanks!
Old 12-15-2004   #2
Jed
The RTFVfaq Guy
Jed's Avatar
Re: 1g n/t head?
The heads are the same minus the cams of course. The later 1g's apparently had better coolant passages.
There are differences as far as the internals go, such as higher compression pistons on the N/T's, no oil squirters and probably a couple other things I'm forgetting or too lazy to think about.
Old 12-16-2004   #3
santa
Boost Spike
santa's Avatar
Re: 1g n/t head?
Ahh no crap. I should have thought about the internals as far as compression, and squirters and things. Thanks!
Old 12-20-2004   #4
LightningGSX
Hellbound
Re: 1g n/t head?
I don't think there's an oil feed for the turbo on the N/T head either.
-Nulli Secundus-
Old 12-28-2004   #5
Sean485
Re: 1g n/t head?
Yes there is, its just got a blockoff banjo bolt there.
The squirters are in the block and compression is controlled by the pistons unless you are shaving a bunch off the surface of the head so you can use a nt head and it will work fine.
