Old 01-01-2005   #1
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
start up
91 Eagle talon tsi AWD. 80xxx on motor.
I just started looking into why the car has extended crank time. So I replaced the capacitors in the ECM, more as a preventative measure. Once the engine is running it seams to run good. The crank time is like five to six revolutions. My thoughts are; timing off, fuel pressure low, compression low, vacuum leak, and poor ignition. So I plan on checking; compression, timing, replacing the PCV and checking for other vacuum leaks, replacing plugs & wires and checking spark, replace the fuel pump (upgrade) the fuel filter is new, replacing the FPR (upgrade). Any other ideas?
Take her to the limit!
