Old 01-06-2005   #1
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
2g walbro pump question
I took off the fitting at the pump and installed it, but I cant get the fiting to get back on far enough so it doesn't leak. I have to twist the hell out of the feed line and it still won't go on far enough. Is the feed line fitting supposed to be so the line turns with it? it seems as if it should be able to rotate on its own but it won't. I looked at vfaq and it said to remove the one under the car instead but that is because of the possibility of damaging the pump assembly. I got it of without doing so. Is the feed line fitting supposed to be able to rotate without the whole line rotating also? Shouldn't I be able to get it on?
7/25/09
