Old 01-18-2005   #1
CarPsyco84
CarPsyco84's Avatar
double syncro
I've been hearing talk about doing this and how it makes your tranny shift so much better and such, but no ones been able to explain what exactly it is, the only thing I can think of is to double up the springs in the shift hub or a completely different syncro,
Old 01-18-2005   #2
Re: double syncro
It is a different gear from a 93-94 DSM. It uses a double synchro on 2nd gear. It shouldn't be too hard to find info on it, check the NABR archives or I know Shindley was just talking about it on MN-DSM yahoo groups.
Old 01-26-2005   #3
Re: double syncro
Its actually a 'conical' style syncro. There is a syncro inside of a syncro if you will. The only problem is the entire gear set/slider assembly is different if I remember correctly. There is the inner syncro piece that goes into the gear? (damm its been a while since i've looked at a dsm tranny) and then a syncro that goes over/around it. The advantages of it is the fact that there is more 'syncro' available to mesh the gears. Hince why the getrag's in the 3s's shift so nice when the proper fluid is in there, triple and double 'cone' syncros .
www.teamrip.com should have some info, also a quick search on dsmtuners or nabr should pop it up like jet said.
