Old 02-03-2005   #1
TGPilot
TGPilot's Avatar
1G Base Timing Set Procedure?
Hey all!
Well I have searched and searched for the proper procedure to do the "Base Timing" on my car. Vfaq says to refer to your service manual and I know I need a new prescription for my glasses...but I do not see the procedure in my service manual. If someone can point me in the right direction or give me a step-by-step it would be WONDERFUL!!
Thanks much!
Kenny
Old 02-04-2005   #2
Tsi
Tsi's Avatar
Send a message via MSN to Tsi
Re: 1G Base Timing Set Procedure?
Go to this link, if that doesn't help I can take it through with you step by step. Its really not that complicated
http://www.plymouthlaser.com/timin.htm
2003 Solar Yellow SRT-4 Stage2 w/toys
99 Isuzu Rodeo
Tsi is offline   Reply With Quote
Old 02-04-2005   #3
TGPilot
TGPilot's Avatar
TSi...Thanks much! That is exactly what I needed...
Old 02-04-2005   #4
TGPilot
TGPilot's Avatar
Well checked it according to the steps on the link you gave me. Without grounding it was sitting at 5* BTDC. Grounding showed between TDC and 5*...more towards TDC. The cam angle sensor was all the way to the max rotated towards the rear of the engine bay.
I set it correctly and seems to pull without flutter all the way through to redline.
Now I need to look into the DSMLink for the car and start playing!
Thanks again!
