Old 02-07-2005   #1
Basic Rebuild questions
Could I get away with rebuilding a stock 1G 6bolt motor with out doing machine work except honing the cylinders and decking headgasket surfaces? I just want a reliable daily driver.
Old 02-07-2005   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: Basic Rebuild questions
Yes
Take her to the limit!
Old 02-07-2005   #3
Impossible to find.
Old 02-07-2005   #4
Originally Posted by Carlos
Impossible to find.
No, he meant one that wasn't worked on by anyone in HORT!
J/K. This is the tech section, no BS posts.
Yes, doing that will be just fine. Make sure you put in the correct sized bearings and gap the rings. Having the crank polished is a good idea too, but may not be necessary.
Old 02-07-2005   #5
Raptor
ConArtist
Raptor's Avatar
You probably don't have to worry about decking it either, check it, I havn't found too many that needed to be decked. The primary reason I have all them done is to make a solid reference for the boring etc. If you are just wanting to get away with a cheap rebuild, probably not required.
Main thing with doing it successfully is to take your time, double check clearances use an accurate torque wrench and do a really thorough job of cleaning. If you have any questions during the rebuild, call the shop.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 02-08-2005   #6
thanks for the answers
