Old 02-18-2005   #1
stikx
Mr -
act2600 car slipping at 4500rpm??
standing still and about to launch, the car moves forward when i try to launch at 4500 is this normal? (i am holding the cltuch all the way down) something wrong with my clutch engagement?
Old 02-18-2005   #2
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: act2600 car slipping at 4500rpm??
Yep.
'04 Honda Ricer: stock
Old 02-18-2005   #3
You need to adjust your clutch pedal.
Old 02-18-2005   #4
Moved to Transmission Tech.
Try this,
Check your clutch rod and pedal adjustments
Bleed your clutch hydraulic system
If that doesn't do it, you may have to look at the clutch assembly itself.
Old 02-18-2005   #5
stikx
Mr -
i searched alrdy, i forgot where that article about how much free play a clutch pedel should have anyone know? 2g Awd
also i know the rear adjustment the one by turning the rod = changing where the clutch engages but what does the other one do? the upper one.
thanks for the help
Old 02-19-2005   #6
Do some stretching excersices and crawl under the dash (on your back). Look to the top and you will see a rod that threads into the top of the pedal asembly. Take a 12mm wrench (I believe) and loosen the jam nut. Take a pliers or vice grip and turn the rod until it is almost all the way out of the pedal. Tighten the jam nut and test the car.
Are you sure you are not on any hill? Also you can try bleeding the clutch. Vfaq shows the clutch pedal adjustment along with teamrip.com. Have fun.
Old 02-19-2005   #7
thanks for the help
What are you referring to as the "rear adjustment"? The last time I checked, everything was in the front of the car. The adjustment I am talking about is under the dash.
A 2600 will limit your free play. Mine has to be dam near touching the firewall before it is disengaged. That is what you get when you upgrade clutches.
Old 02-19-2005   #8
stikx
Mr -
i know its under the car near the clutch pedel but under there there are two adjustments right? one is to change the clutch engagement whats the other one do?
Old 02-19-2005   #9
There is only one that I have adjusted. It is at the top of the pedal and the rod runs through the pedal and into a boot that you see. If you look under the hood you will see where it comes out at the fluid resivior (cannot actually see the rod but it will give you an idea on where to look under the dash. Vfaq has a diagram alone with teamrip.com. That is the only adjustment I know about. QPR has longer clutch rods which may help. I got one but I dont believe I have it in my car anymore. It is supposed to move the clutch pedal furthur off the floor.
Old 02-19-2005   #10
Wizard
Stainless braided clutch hoses/lines, billet clutch fork, longer slave rods, modifying the master cylinder, shimming the pivot ball......The 2600 has plagued DSMers since it's intro. I would try adjusting it some more, invest in some stainless lines (allows you to eliminate the FPR), then either purchase longer slave rod or you can try shimming the rod temp. to see if that fixes your problem.
Wiz
Old 02-19-2005   #11
2600's work just fine if the rest of the system is up to par. The problem is usually a worn clutch fork/pivot ball or the pedal assembly. I am pretty sure it is a 1g, so there is no restrictor in the line. The SS line on a 1g doesn't do much (I have one).
Bleed the system, then adjust the rod that is right by the top of the accelerator pedal. If that doesn't do it, it is probably your pedal assembly, check that.
Old 02-19-2005   #12
Wizard
He said he had a 2g AWD....that's why I mentioned that. If he had a 1g, then I would have him check the clutch pedal assembly....that's a given. As well as the other hydraulic components which often fail after a 2600 install.
Wiz
