Old 02-26-2005   #1
armthelaser
armthelaser's Avatar
air/fuel ratio gauge
I have a auto meter air/fuel ratio gauge, do I need a sensor to make it work for my 92 plymouth laser?
armthelaser is offline   Reply With Quote
Old 02-26-2005   #2
Re: air/fuel ratio gauge
No, it just splices into your wireing harness to the ECU. There are wireing diagrams around that tell you what wires you need to tap into. I am sure someone is going to say it so I might as well be the first. Them gauges really do nothing for you except look pretty.
CRAIG
Old 02-26-2005   #3
armthelaser
I got it free from a car at my work so if its easy to install I thought what the hell. Thanks for the heads up
Old 02-26-2005   #4
go the www.vfaq.com I think there is a wireing diagram on there. And yeah its really easy to install. I bet lightninggsx has a diagram saved on his computer for a 1G ECU. I had one but I can't seem to find it.
CRAIG
Old 02-26-2005   #5
Looks to be relatively helpful: http://www.vfaq.com/mods/wayback/Bra...l/find-o2.html
Old 02-27-2005   #6
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
there should be a connector in the pass side kick pannel you can just plug into. check vfaq.
11.35 @ 120mph
