Old 03-03-2005   #1
SpicyOrange
What is the stock Boost level on a 95 GS-T?
I recently hooked up a boost gauge in my 95 Gs-t and I see 14psi all the time? Is this high for a stock motor without a boost controller? I now the kid before me removed the little restrictor in the line that gives you 1-2psi. But what do they leave the factory with?
Thanks,
Nick
SpicyOrange is offline   Reply With Quote
Old 03-03-2005   #2
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
Re: What is the stock Boost level on a 95 GS-T?
2Gs typically run about that with the restrictor out.
Old 03-03-2005   #3
SpicyOrange
Ok I thought it seemed high but I know nothing about these cars. Trying to learn quick tho. Thanks for the reply.
Nick
Old 03-05-2005   #4
TalonTSI95
what restrictor are we talking about? sorry i'm a newb.
TalonTSI95 is offline   Reply With Quote
Old 03-06-2005   #5
Wizard
From what I found a while ago, 1g's run at about 11psi (Of course only 9psi is typical because of the puny exhaust) and 2g's are set at 14psi. Of course on a 2g, anything over 11psi and the stock BOV leaks. The BCS mod usually bumps up the boost level 1-2 psi. But this is all dependent on your exhaust and BOV.
Wiz
