Old 03-08-2005   #1
TGPilot
TGPilot's Avatar
Cruise Control Surge
My 1994 Talon TSi has terrible cruise control surge. I don't know if this is a common problem or if there is a way to fix this...but input would be greatly appreciated.
My Talon has a big 16g, EVO III manifold, bigger fuel pump, etc. on it and the boost hits right at 3000-3150 RPM. Highways here in Colorado are 75 MPH limit and at 75 my RPMs sit at 3500. If I set my cruise to 75 or even 80, it will hold ok until I hit a slight up-hill or come off a downhill. What will happen is the car will be at 75...drop to 73...cruise will try to recover to 75 but it will boost to 10 psi before it gets to 75 causing a serious rise in MPH. The cruise will back out of the throttle abruptly (normally at 77) then go back down to 73 and hit 10 psi all over again and again and again!
With the State Patrol hitting my commute area real heavy lately, I would like a functioning CC so in my sleep while I am driving to work I don't have to pay so much attention to my speed!
Is this common for all "modded" TSi's or is there something I can do to adjust the sensitivity of the CC?
Old 03-08-2005   #2
Wizard
Re: Cruise Control Surge
The main problem you have is in the cruise itself. The cruise unit consists of a couple pulleys that attach to a servo motor. Often, with age, these pulleys get gummed up with dirt, etc. This causes the cruise to react too slowly to maintain slow, steady control. Kinda like a sticking throttle. You have to push extra hard to get it to budge, then it moves too far, etc.
You have 2 options:
Remove the cover and using brake cleaner, etc to clean the pulleys and the cables. Then relube with some white lithium grease, etc.
Buy a cruise eliminator cable.
Wiz
Old 03-09-2005   #3
TGPilot
TGPilot's Avatar
Hey thanks wiz! I will pull it apart and see if it is dirty and such.
Assuming by the name "cruise eliminator" that kills the cruise? I want it to work correctly if at all possible...
Old 03-09-2005   #4
TGPilot
TGPilot's Avatar
Wiz...just wanted to follow up. I cleaned and lubed (Tri-Flow my favorite!) the cruise unit. WORK$ PERFECT! In fact there was a bit of tightness in the cables so I pushed Tri-Flow down into the cable sheaths and now I have to relearn my throttle pedal...very smooth and easy to use now!
THANKS AGAIN!
Kenny
Old 03-09-2005   #5
Wizard
Glad to see that you saved some money and headache.......
Enjoy.
Wiz
