Old 03-09-2005   #1
BOV questions..
Ok. I used the search function, but I fould no results, pertaining to what I wish to know. I wanna know what makes one person chose one bov over the next? It seems to me that they all do the same job, so why choose brand A over brand B? I also was curious as to how the hks ssqv works, because I think I heard the flapper design is different then other bov's. What makes it such a popular brand bov? Anyone here use the Greddy type S?
-A. Swift
Old 03-09-2005   #2
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: BOV questions..
Sound, price, and functionality. I run the Paul Walker special(aka Greddy Type S). I like the not so screaming sound that it makes, but it is still loud enough to scare off the occasional ricer. It have pushed it up to about 35psi on accident and it has held just find. Plus when I needed to I could recirculate, there are some BOV's you can't recirc(ie Tial). You need to get one that will match your setup and your goals. Most of the high boost and power applications use a Tial as it is very stong and also pretty quiet. I am not planning on pushing an assload of power, so I didn't think I would need a Tial. The only thing I wish I would have known before was that the Type S came in grey, instead of the gay purple I have now.
Also keep in mind that a properly crushed 1G BOV will hold about 25 psi, I have seen that you can even mod them to hold just as much boost as a Tial.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 03-18-2005   #3
Re: BOV questions..
Well, I kinda think the deep purple looks sorta cool, but that's just me..and, I am not gay..it's just a color. Anyway, the MAFT will be moved more towards the IM, making it more accurate, but will this mean that I can vent, and it be safe?
-A. Swift
Old 03-18-2005   #4
Khadgar
Can't Actually Wrench
Re: BOV questions..
I loved my type S while I used it, now I have a purple Tial on order. I love that color.
Old 03-18-2005   #5
Re: BOV questions..
As long as the BOV if before the MAFT, you can vent it. Check out the pic's of the 2G in my member offered services thread. He has a MAFT in the UICP and the BOV vented just before it (about 10" before). It works great. There is a thread we did not long ago talking about the different BOV's. I will try to find it.
Old 03-18-2005   #6
Re: BOV questions..
The HKS SSQV is a "Pull Type" Blow off valve that its great for automatics because it stays fully closed at idle so you can (but still not recommended) vent to atmos with out it killing on you.
Straight off of the HKS site:
The HKS Super Sequential Blowoff Valve (SSQV) is a dual stage pull type relief valve. Unlike other blow off valves that are push type, the SSQV will not leak under high boost conditions nor under vacuum at idle. Being of a pull type valve structure, the SSQV can not physically leak under any level of boost because boost pressure also keeps the valve closed against its seat. The SSQV is actuated by pressure alterations only, not by the rate of pressure or vacuum in the line, which ensures a quick valve response and complete closure during idle. On typical blow-off valve designs, a large valve is utilized in order to accommodate high boost / high horsepower applications. However, these large valves tend to react slowly and require high activation pressure to open, therefore are not able to activate and prevent compressor surge at light-load conditions. On the other hand, smaller, fast reacting valves do not discharge the airflow capacity required for high horsepower applications and tend to creep open and leak as the boost pressure overpowers the spring on these push type valves. For maximum performance, the HKS SSQV incorporates both a small primary valve for ultra quick activation, along with a larger secondary valve for additional discharge capacity. The SSQV is engineered to initially open the small primary valve at light throttle and load conditions, then sequentially opens the secondary valve for additional relief capacity under high boost and load conditions. The SSQV is constructed of polished billet aluminum, which ensures long-term durability and visual appeal. The mounting base utilizes a circular mounting flange that provides exception flow and complete secure mounting via a C-clip snap ring and O-ring gasket. The triple-fin discharge port design produces a powerful and unique aggressive blowoff sound along with added visual distinction.
Old 03-18-2005   #7
Re: BOV questions..
dang..I am tempted with that bov, but I think i'll stick with the type-s. I see on ebay that there is a bov that looks EXACTLY like the type-s, but it's sold by thestreetsource.net? Anyone know if these are good, or a cheap knock-off?
-A. Swift
Old 03-19-2005   #8
TheBlackKnight
Mad Urban Biker
Re: BOV questions..
My 2G came with a SSQ and I like it! For the functionallity is does hold up to like 35psi or something even though I am running like 16psi right now. It sounds cool though and is decent looking for those show car gus around here.
'98.5 BMW M3 Dinan S3-4
'89 BMW 325I, stock
'95 Talon TSi AWD sold
TheBlackKnight is offline   Reply With Quote
Old 03-19-2005   #9
Re: BOV questions..
-A. Swift
Stray away from the eBay knockoffs. I believe only recently did the fake Type-S start showing up. I stand clear of any automotive part on eBay that did not originally come direct from the original manufacturer.
Old 03-20-2005   #10
Re: BOV questions..
Well, i was bidding on a type s off of ebay, but i lost out on it. Anyway, anyone ever purchase from blowoffvalves.com? They look reasonably priced. One thing i noticed, is that when you click on their greddy link on the side, and it takes you to the page of what they sell..they have a type s that's sold with a tube for the 1g dsm. It looks that instead of having to weld, it is already bolted up to a tube, that you just replace the stock black elbow with this one, and boom! done..only 187 bucks? interesting. Is this BOV loud? It sounded loud, with the sound file of the tt supra.
-A. Swift
Old 03-20-2005   #11
Re: BOV questions..
Crap, I also forgot to ask what The difference was for the type s, and the rs, and the type r. Isn't the type R for higher pressure? What bov works best in what psi area? Thanks guys.
-A. Swift
Old 03-20-2005   #12
Re: BOV questions..
I believe that the Type S is the discontinued model which is geared as a more versatile blow-off valve. I believe the Type R is geared for higher pressure applications. The Type RS is the new model to replace the Type S but I believe it only comes available in a vented configuration.
What not just call up Elite, SLS, or QPR to order a blow-off valve?
$187 for a Type S is not that cheap, I have seen them all the way down to $175 shipped before.
Old 03-20-2005   #13
Re: BOV questions..
Well, I was stating that I think that price was higher, because it comes with the elbow for a 1g. That way, no one needs to weld anything. I figured the type s is discontinued, and replaced by the RS (that's the silver one, with the blue bell on it?) but I heard that with the 8 holes it has, the RS is louder then the other. I want a bov that sounds nice, and not too loud. I don't need the whole neighborhood hearing what I have.
-A. Swift
Old 03-20-2005   #14
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: BOV questions..
I look at that, and I don't understand what it is for... I have a Type S, I got the universal one, re drilled the holes on the 1G BOV flange(they are closer together than on the 1G valve), and voila. Yes I am venting mine, but you should be able to get the original recirc tube from the stock BOV to fit onto the Type S. No need to pay more for something that you don't need. Extreme PSI has a good price on them and doesn't charge shipping on anything from what I remember. And stay away from a Type R, unless you are going to be running 35 pounds of boost, then just buy a Tial.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 03-20-2005   #15
Re: BOV questions..
Ok. I was gonna have the MAFT moved towards the intake manifold, so venting won't hurt anything. I will be venting. Where is this website you speak of? Also, where might I find a flange that I can weld to a bigger charge pipe, for this bov?
-A. Swift
Old 03-20-2005   #16
Re: BOV questions..
Check with Elite and QPR also. They can usually match prices or get really close. Support the DSMStyle supporters!
Old 03-20-2005   #17
Re: BOV questions..
VERY true..I'll hafta visit my local elite..in st. cloud..where tyler, randy, and the other xrated boys tune.
-A. Swift
Old 03-20-2005   #18
Re: BOV questions..
one thing i would never buy on ebay is a knockoff mechanical item, (i.e item with moving parts) when you have an inatimate item like a FMIC core or Downpipe theres not much that can go wrong, but when you have a knockoff mechanical item theres a lot that can go wrong because their are moving parts if the BOV doesnt open or causes damage to your turbo then your our a turbo and a Bov and what else could go wrong. If i would buy like a bov or safc etc off of ebay then i would go for a name brand item.
Old 03-25-2005   #19
Re: BOV questions..
cool. I will look for a greddy type s then. Anyone ever use a blitz dd? is it loud, sound good, or what?
-A. Swift
Old 03-25-2005   #20
Re: BOV questions..
I have installed several Blitz's on customers cars. I like the Greddy Type S a lot better. The Blitz is really small and seemed to be cheaply made.
