Old 04-09-2005   #1
DSM1G
DSM1G's Avatar
Drives: 1993 talon tsi, 2003 dodge ram
Send a message via AIM to DSM1G
does anyone have an automatic 1G?
hey I was wondering if anyone one here has an automatic 1G that is making a decent amount of horsepower at the wheels? The only reason I ask is because I have modded it a little bit so far and I think my horsepower is lower then it should be for what I have done.
So far I have:
QPR built motor, ported Evo big 16G, manual boost controller, 550 injectors, 2G MAS, Walbro 255 fuel pump, S-AFC, 3'' exhaust and high flow cat to muffler tip, ported 2G exhaust manifold, End clutch kit and IPT high stall converter. I also just got it back from Elite having it dyno tuned.
I think I need to get a front mount next but I was wondering what other people with autos where running for their setups?
Thanks
DSM1G is offline   Reply With Quote
Old 04-10-2005   #2
Re: does anyone have an automatic 1G?
What did you end up with for dyno numbers? Also what PSI and did you do any tuning while in the dyno?
I dont think there are any other autos on here that have extensive mods that I know of. I know nightrider on here has a auto 1G but has never dynoed it to my knowledge.
I would think with your mods you should be putting out around 300+.
Old 04-10-2005   #3
DSM1G
DSM1G's Avatar
I am running 16 psi. And I guess Shane at Elite said he didnt have to tune it too much because with the 550's and the 2G MAS it pretty much was running where is should be.
Old 04-10-2005   #4
I haven't dyno'd my car, but i'd be suprised if it broke 200whp, but Im only running stock boost.
I figure with a boost controller, 200ishwhp give or take 30.
Old 04-14-2005   #5
Aaron
I have one... It does not have many mods yet, but she will
Stock 13g Turbocharger
Hks Type 0 Turbo Timer
Hallman ES manual boost controller set at 14 psi
Crushed 1g Blow Off Valve
2.25 Upper Intercooler pipe
Manual Cams
Ralliart 4 Layer Steel Headgasket
removed all emmissions and vaccum lines
removed AC
Cold Air Hack
K&N Air Filter
No Airbox
Removed lower honeycomb
backed out screw to flush
Fuel Modifications
450 cc Fuel Injectors
Manual FPR
Driveline Mods
TransLab Shift Kit with Street/Strip Spring
Link:
http://aaron.fugeelama.com/Talon.html
~Aaron
Aaron is offline   Reply With Quote
Old 04-14-2005   #6
Wizard
I got one too......91 RS FWD.
14b powered. Dyno numbers soon.....
Wiz
Old 04-14-2005   #7
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
My guess you are makeing around 249 WHP with race gas. I’m assuming you have a FWD, with a .20% (62hp) loss (automatic) of power from 311 hp at the eng.
Take her to the limit!
Old 04-15-2005   #8
Wizard
Is that for me? I should be trapping close to 105-106mpg on race gas. And according to the handy calculator, that should be around 270+whp.
Wiz
Old 04-15-2005   #9
CDeutsch
CDeutsch's Avatar
If any of you auto guys need a rear LSD let me know. A case of beer and it's yours.
06 Evo IX RS
99 Miata
Old 04-16-2005   #10
Wizard
I need an AWD to use that.
Wiz
