Old 12-06-2003   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
So it looks like I won't just be pulling the motor after all. I need to do the clutch and get her back on the road as my winter car is slowly dying.
I have looked over the VFAQ on removal of trans and all that needs to be done along, with looking through my Chrysler manual and Haynes manual. My main question is there anything else that may be common sense to do that was not listed on any of the above resources(balancing components, resurfacing flywheel, leaving out or adding any bolts nuts or screws)?
While I am doing that I will also do my cams and was told I would need a timing belt tensioner tool to do them correctly. Now I know I could easily make a one or two time use tool, but I have this thing about using the right tool and was wondering where I could get the correct part from, as I see the number for it on the TBelt VFAQ. Same goes for the clutch, any special tool that I might need?
Last concern is that I have noticed that three of my T-Case to tranny bolts don't really tighten down, they keep spinning until they back themselves out a little bit. I have some loctite on them now, but know I should get it fixed. What do I need to do to the tranny to get this fixed and where could it be done?
Sorry about all the noob questions but I want to do it right and know I can count you guys for the right info.
Thanks in advance.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
