Old 04-21-2005   #1
Onefast99gsx
Question 2g with 50trim intercooler plumbing help needed
Ok, i need some help here in knowing how/where to route the pipes from the turbo to the intercooler.
Car- 2g GSX
Turbo- PTE 50trim t04e housing outlet facing straight down (no elbow)
I was just gonna use a good poly-rubber 90* elbow.
My intercooler inlet is on the bottom right(passenger) side just under the fog light. How do i plumb to the intercooler inlet. I kinda semi-fitted things last night with the stock rad. fan and man it looks tighter than bitch. I don't see how to even begin to plumb this. How do you guys run yours. Do i run straight down from the turbo, then to 90* and go under the crossmember, which would not leave much clearance from the pipe to the ground.
Any help would be appreciated. I need to order some mandrel pipe and couplers possibly by tommorow.
Thanks.
