Old 04-25-2005   #1
Onefast99gsx
Question ARP Head bolt install help needed.
I've been on both tuners and dsmtalk and i see about 3 different methods people use for installing ARP head bolt studs. Can someone please share what method you use.
With the ARP moly lube that comes with, they say 65lbs.
In the torqueing sequence, do you just do the first one at 65lbs, then the 2nd, 65, etc... ? Or do you do do them all at like 40lbs, then 50, then 65lbs?
Also the factory manual says something about a torque/ untorque/ retorque. Does that apply for ARP bolts? Or do you just torque them and leave them.
Thanks for your help.
