Old 04-27-2005   #1
DSMkel
Send a message via AIM to DSMkel Send a message via MSN to DSMkel
Building new engine
The 7 bolt has reached 145K, has a few issues, but in the long run is still running strong. Figured it was time to start the 6 bolt buildup. Plans are to build it for a T3/T4 setup. I basically just need suggestions for the build up if anybody has had experience with building for this kind of setup.
I have a block that came from a 91 Laser, as far as I know it will need to be bored 20 over just to be safe. Will I be able to use stock pistons or should I use aftermarket and what kind? Wut will I need to anything special with the crank?
Type-Arrrrgh KILLA
"If it's never broke you're not driving it hard enough"
DSMkel is offline   Reply With Quote
